08-27-2019, 08:14 PM | #1 |
Logo Lites USB Charge Port
Can anyone share their experience of installing the Logo Lites USB Charge Port from Bratton’s? I’m interested in where you installed it in the car, how you connected it to power, etc.
https://www.brattons.com/usb-charge-port-accessory.html Sent from my iPhone using Tapatalk |
08-27-2019, 08:37 PM | #2 |
Re: Logo Lites USB Charge Port
Apparently you can just wire in a cigarette lighter and use a regular charger. I made my own dedicated charger before I knew this because I didn't want to spend the money. The logo lites unit seems nice though, and easy to install.
08-27-2019, 10:02 PM | #3 |
You need to make sure the outlet to the plug will recognise 6v and deliver the 51/2v required. Isolate the plug.
08-28-2019, 04:02 AM | #4 |
The instructions say it works with 6V positive ground. http://www.logolites.com/wp-content/...tionManual.pdf
Can anyone share where they mounted this device? How did you make the power connects? Were there any problems with the installation? Sent from my iPhone using Tapatalk |
08-28-2019, 08:46 AM | #5 |
08-28-2019, 09:21 AM | #6 |
08-28-2019, 09:25 AM | #7 |
Hello Shew, I purchased mine directly from logolite. I mounted mine directly to my steering column on the very bottom, easy to reach and kinda out of sight. I secured it with 2 or 3 zip ties with a rubber pad to hold it in place, there is also a strong magnet on the unit to hold it in place. As for power connection I went right off my junction box on the firewall, was an easy setup. The unit has been on for a few years and Ive had no issues at all. Good luck with yours and Happy Motoring, Dutie
08-28-2019, 12:10 PM | #8 |
Hello Shew, Sorry for misreading your post. My post was for the signal light installation and not the charge port....anyway good luck with your setup. Dutie
