07-04-2018, 08:08 AM | #21 |
Re: The perfect battery shutoff?
07-04-2018, 03:06 PM | #22 |
My perfect batter shutoff is my fingers. I always disconnect the + battery cable when putting the a car away. Yeah, on my 33 I have to bend down, fold the mat back and lift the wood cover. That is a lot less bother then several burned up cars and a burned up shop. The V8 times a few years ago had pictures of a guys garage that burned up toasting several expensive cars not to mention his shop and tools.
When I want to drive any of my old Fords, I can push on and twist the connecter onto the battery post and it starts and charges fine. I have been doing this for 20 years and never had any kind of problem. I hook/unhook the battery tender anyway so I am at the battery location. Works for me. |
07-04-2018, 03:39 PM | #23 |
I have used the one that Pet Hoovy posted,Green knob no problems for years now ,it needs to be tight ,Ted
07-04-2018, 03:49 PM | #24 |
There are a lot of complaints about the ones with the green knob shown in "PeteHoovey"'s post, but I have used them for years. Every time I use one, I take a piece of sandpaper and make sure that the contact surfaces are clean and shiny. I've never had any problems with them. I'm sure they could become a problem if you let them get dirty or corroded.
07-04-2018, 03:56 PM | #25 |
I still use the often criticized "Green Knob" switch that mounts on one battery post. It is not expensive and doesn't require running heavy cables or other modifications. It is reliable, and the knob can be unscrewed and removed to foil theft.I have had them on all my cars. I get them from C&C (800-266-0470) as part number A-143000-C, $13. The also stock a permanent mount type, A-14300-D, $30.
07-04-2018, 04:36 PM | #26 |
07-04-2018, 05:08 PM | #27 |
For the old cars, lack of fused circuits is the best reason. A burning wire can start a fire. It was relatively common for cars to catch fire back in the 19-teens & twentys.
Wiring got better in the thirtys & fortys but that old cloth covered stuff likes to deteriorate unless it is updated. Most all aircraft still have a master switch so that the battery can be taken off line if problems arise. The recip aircraft all still have magnetos and turbines are good if the fire is still lit so they will keep running in the event of an electrical failure. |
07-06-2018, 07:47 PM | #28 |
In the old wiring there's something Rats like ,latex ??
07-06-2018, 11:28 PM | #29 |
I use one one because my solenoid caught on fire and I didn't have the proper size wrench with me to take a batt cable off. I now have a shut-off AND appropriate wrenches. I was lucky!!
