04-19-2021, 11:43 PM | #1 |
Max Speed of a Model A with 26% OD and HC Head
For member with a Mitchell 26% overdrive and a HC Head at 5.5 or 6.1.
What is the max speed you had your car at and at what speed do you feel comfortable at for extended periods of time. I have a feeling that the max speed will be quite high. Ron |
04-20-2021, 02:05 AM | #2 |
Re: Max Speed of a Model A with 26% OD and HC Head
All I can tell you is that I run sustained 68 mph in my Model A (per Garmin GPS readings) with a standard Model A 3-speed trans. I have 12 volt modern point system, a lightened flywheel, balanced crankshaft, and a Weber Two barrel carb with the modern intake. I also add Lucas lubricates in both the engine and in the trans. I have had enough sports cars to 'know' that it does make a difference.
I am also running 1935 wide-rims and radial tires with a piston stabilizer on the steering and 'float-a-motor' rubber engine mounts front and back – past 55+ the car handles with limited vibration and little perceivable shimmy. I have read here and other places that I can add an additional 5+ mph if I use a cast iron header exhaust and different muffler system, but have not done that as of yet. I use a four blade fan for cooling here in Florida, but I have also read that the use of a six blade plastic fan will work better and reduce the drag on HP and speed. Another advantage to consider. Lots of changes that can really perk up the wonderful Model A. |
04-20-2021, 12:22 PM | #3 |
Gear ratios can be deceiving. Just because mathematically it will raise your speed, if you don't have the horsepower, you won't go as fast as you think you can. Pushing a Model A thru the wind is like pushing a barn.
04-20-2021, 01:40 PM | #4 |
Remember what kind of brakes these cars have. Especially if you’re not using cast drums.
04-20-2021, 01:55 PM | #5 |
Ron I am sure many will disagree but I am quite surprised that a new owner such as yourself seems to be obsessed with attaining excessive speed. Maybe you should have purchased a type of race car instead of a 90 year old classic. JMO, Wayne
04-20-2021, 11:08 PM | #6 | |
I have multiple cars for that kind of driving and regardless of how fast they go I never exceed 5 to 7mph on the interstate. That said I have no intention of ever using my Model A on the interstate. I am interested in hearing what people can attain with 6.1 head and a 26% Mitchell as this is what I will be running. By knowing what the max performance is with an otherwise stock car I am trying to judge an optimum max cruise speed without causing damage to my engine for long distance driving. I do think the best speed for a Model A is 40 to 50mph but secondary roads tend to be 55 to 60 when you get out of town. In my opinion my car is safe at 60 as my steering, brakes, suspension and front end have been refreshed but the engine is turning just a little to fast to hold that speed in my opinion. I am not trying to build a race car out of my Model A rather make her a little more drivable. I am the kind of guy that would love to drive across the country someday in a car that's pushing 100 years old. I know that may be strange for some but to me that's a great way to get out of work and spend my vacation experiencing Small Town America. Ron Last edited by Model A Ron; 04-20-2021 at 11:51 PM. |
04-21-2021, 01:59 AM | #7 |
My 1930 Town Sedan has a 5.5 HC head, standard 3.78 rear end, and a 26% Mitchell OD. The previous owner restored the car and had the engine re-built, so I do not know exactly how well things were balanced. My steering, brakes, and tires are all very good, and I feel quite comfortable doing a sustained 55-60 mph. I’ve never tried running it as fast as it will go....I’ve hit 65 a few times, but 60 is my upper limit for comfortable cruising.
04-21-2021, 03:04 AM | #8 |
Back in the day my car did 65
04-21-2021, 08:04 AM | #9 | |
Ford marketed the model a as a car 'to meet todays (1927) demand for speed and comfort'...With modification it still does,90 years later.. |
04-21-2021, 09:35 AM | #10 | |
04-21-2021, 09:39 AM | #11 |
I have a 6.1, larger intakes, model B carb with bored out intake, touring cam, lightened flywheel, 26% overdrive, cylinders bored .60 over, electronic ignition, 3.78 rear end.
Very comfortable at 55MPH, 60 is OK but the rpms are getting up there, 65 no problem but it seems a stretch. |
04-21-2021, 09:48 AM | #12 | |
"It was my desire to prove the basic model a platform relevant in todays driving conditions, to run anytime without the protection of a convoy." |
04-21-2021, 05:24 PM | #13 | |
04-21-2021, 07:19 PM | #14 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
04-21-2021, 08:59 PM | #15 |
Without getting into the details of the physics, it takes a certain amount of power to push a car along at any given speed. As the speed rises, the resistance increases till you reach a point where the available power is all used to maintain what is the maximum speed of the car. So long as there are no silly gearing issues etc, O/D or not will not make much difference to the top speed. The O/D does not increase the power available. The HC head makes a bigger difference.
That said, if you want to travel at say, 60 mph, the car is happier with the O/D. Things are not so busy under the hood.
04-22-2021, 01:01 AM | #16 |
If you want to travel at 60mph you need a V8
you got your new engine yet Arnold. My shed is full of them Lawrie |
04-22-2021, 08:04 AM | #17 | |
Ron Last edited by Model A Ron; 04-22-2021 at 08:10 AM. |
04-22-2021, 08:16 AM | #18 |
With stock wheels and tires 62 requires real good roads.. even with 16's and modern radials you have to 'give her her head'.. don't try to hold her on a string, just 'herd' it down the road. Everyone agrees the car is comfortable at 45 no matter how much you do to it.
04-22-2021, 08:21 AM | #19 | |
04-22-2021, 10:01 AM | #20 |
My Fordor has an overdrive, 5.5 head, Weber, insert bearings, cam, etc. I have had it up to 70 with more to go but I like driving it at 55. It has excellent brakes and steering so I do not feel threatened at 55 or even 70. The engine HP was estimated at 90 by the builder but I suspect it is more in the 70 range.
