Old 03-16-2021, 02:08 PM   #41
oldford2
oldford2's Avatar
Default Re: Fan Belt Tension Adjuster....
Most of the belt tensioners tools were for an 8ba. The 59 engine wire looms don't allow their use. Here is one I made that provides a fulcrum point a bar or piece of wood. uses a front manifold bolt to attach. John
oldford2 is offline   Reply With Quote
Old 03-16-2021, 02:17 PM   #42
oldford2
oldford2's Avatar
sorry, double post
Old 03-16-2021, 03:04 PM   #43
35ragtop
35ragtop's Avatar
Good idea John,
we also have the problem on a 59 engine with adjusting the smaller fan belt. It is a real fiddly job to get it tight enough and the bracket square to the generator bracket. The only place to lever off is the distributor vacuum piston bolt which I dont like doing.
Any suggestions?
Dave
35ragtop is online now   Reply With Quote
Old 03-16-2021, 10:23 PM   #44
Tinker
Tinker's Avatar
We are still talking about adjusting a belt right???
I believe the stock tension is 3/4" tension play in the belt no matter how you get there. Meaning after its tight you can push the belt in 1/2 to 3/4'.
Old 03-17-2021, 11:36 AM   #45
Art Newland
Art Newland's Avatar
Originally Posted by 3twinridges View Post
We had good luck using an engine hoist and a strap to set the tension on the generator and fan belt. I think I picked that up over on FTE.
JB
I have to agree here. As long as you have a cherry-picker style engine hoist readily available, it's very simple to roll it over to the vehicle, put a strap ( I use an old piece of ratchet-strap) around the generator. It's very simple to very precisely add belt tension. The only bending over needed is to loosen/tighten the mounting nut. It may sound like over-kill to use a hoist, but I didn't have to fabricate anything, it doesn't scratch anything, and my back doesn't hurt when I'm done.
"whatever works!"
Art Newland is offline   Reply With Quote
