05-05-2020, 03:49 PM | #21 |
Re: Preventing electrochemical corrosion alloy heads
I agree completely with Franks ford. STAY AWAY FROM USING REVERSE OSMOSIS water. We have a home on an island off the Gulf coast. When the island went to RO water eventually every copper pipe virtually dissolved and all homes had to be completely re-plumbed with PVCE pipe. I also have a friend who was a printer back in the day. When they went to RO water their presses dissolved. The problem is RO water is very aggressive even though it is intrinsically pure. A good quality antifreeze is all you need.
05-05-2020, 05:18 PM | #22 |
gmdv>>>Interesting subject. I just pulled the water pumps. They were rebuilt by the guy in Florida and installed eight months ago. Used Ethylene Glycol (green stuff). 50/50. We have pretty hard water. Should a guy use premixed modern anti freeze.>>>
Yes. Definitely. Premix for your flathead. And bottled water for brushing your teeth. 8^) Jack E/NJ |
05-05-2020, 10:23 PM | #23 |
Well I didn't know you could buy those zinc anodes already made up, but yes, they closely resemble what I make.
05-05-2020, 10:33 PM | #24 |
These are commonly used on boats, so boat supplys should have various products.
05-05-2020, 10:48 PM | #25 |
RV supply stores also have sacrificial zinc anodes because they are used inside the rv water heaters.
05-09-2020, 09:26 PM | #26 |
