Old 04-10-2020, 03:54 AM   #1
fredski53
fredski53's Avatar
Default Cam spring
Does anyone know the correct length of an original cam spring? The replacement spring I got from Snyders I think is too short.
fredski53 is offline   Reply With Quote
Old 04-10-2020, 07:34 AM   #2
Joe K
Joe K's Avatar
Default Re: Cam spring
I have just examined two I could access from engines "apart."
One of these measures 1-3/16. This one I don't give a lot of credence to since it came from a timing cover where the plunger was "stuck" in place flush with the boss which contains it. The cam was obviously free to move forward and back and had worn the plunger boss. The spring itself seems somehow "thin" and weak.
The other measures 1-1/2. This one I put to "more original" of the two. Fully functional albeit worn engine when removed. No evidence of modification and the spring seems somehow more "stout." This one I would re-use after wire-brushing.
Hope this helps. I see at least one new spring in my Model A future.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-10-2020, 09:35 AM   #3
redmodelt
redmodelt's Avatar
Even if the spring is shorter, under compression it could still have the same force of the original if the diameter of the wire used to make it was larger.
If the spring for example needed to be compressed to say 1 inch, a spring with larger diameter wire would need to be compressed less to get the same working force as a spring that was made of smaller diameter wire.
Example; If spring A with larger diameter wire is 1-1/4 inches long and when compress to working length of 1" has a force of 15 LBS (numbers are examples for illustration only, not real) and spring B with smaller diameter wire is 1-1/2 inches long and when compressed to 1" has the same LBS force.
Both springs would work in the case of the plunger springs because the working length changes very little. As springs are compressed the force increases, that is why valve springs have two working numbers, closed and open given in most cases given in pounds force.
Old 04-16-2020, 11:15 PM   #4
burner31
burner31's Avatar
My computer is messing up so I can't post pictures, so, let me say...
Just changed out on original spring and plunger, plungers looks the same so no issue there, but the springs are way different, original is thinner wire but much longer, new one is thicker wire and much shorter but more stout.
After fitting the old against the new on the engine I noticed that the compression felt more or less the same until the cover started tightening against the engine, the new short one felt much stronger and better to do the job.
I went with the new short spring.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-17-2020, 07:02 AM   #5
Joe K
Joe K's Avatar
This is one for "Doc" Kalinka - who wrote for the Model A Magazines with (dare I say) original research on the Model A. Doc's articles inspired me to collect the whole set of "Technically Speaking" of which his articles played center stage.
Doc would take on a component inspired (usually) by some anomaly found at a Flea Market - and usually ending up for an afternoon at the Benson Archives and would tell you everything you needed to know.
But alas, Doc passed in 2016. Certainly missed.
https://www.wietingfuneralhome.com/o...kalinka-dvm/s/
Joe K
