11-24-2019, 06:14 PM | #1 |
Intake manifold bolts
Quick question, short answer.
Do the bolts for intake require a lock washer, flat washer, or no washer at all. |
11-24-2019, 06:56 PM | #2 |
Re: Intake manifold bolts
Not sure what if anything is required. I kind of like alloy steel black oxide allen head bolts with SAE flat washer. Not close to stock but it looks good with aluminum intake.
11-24-2019, 06:57 PM | #3 |
Cast intake NO washers authentically. Aluminum intakes required hex head bolts and cadmium plated flat washers.
11-24-2019, 08:13 PM | #4 |
Thanks guys, it is a cast iron intake, really appreciate the responses.
11-25-2019, 08:50 AM | #5 |
There is no reason to NOT use a hardened flat washer - underneath a lock washer (at least that is how I do it). This helps prevent galling on the surface and makes for a bit nicer tightening/torque sequence. Now - if you're building a 100% perfect restoration, you'd need to do what Henry did - and I have no clue as to exactly what that is! What I do know is that the intake bolts from Ford are very specific to the intake manifold . . . easy to recognize even in a pile of hardware!
11-25-2019, 01:19 PM | #6 |
