Old 04-01-2019, 06:06 AM   #1
lotsagas4u
Default 1933 rear wheel bearing?????
Guys, what grease do you use in the rear drum roller bearings? Sta3131? A light layer of this? Thanks
lotsagas4u is offline   Reply With Quote
Old 04-01-2019, 10:50 AM   #2
supereal
supereal's Avatar
Default Re: 1933 rear wheel bearing?????
Sta-Lube drum brake wheel bearing grease worked well into the rollers with a light coat over all before installation into the hub.
supereal is offline   Reply With Quote
Old 04-01-2019, 11:11 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Yes, repacking those rear roller bearings with Sta-Lube 3131 fiber filled wheel bearing grease is the way to go.
John
