07-27-2014, 01:58 PM | #1 |
Amp meter
Could bad amp meter cause generator to max out put and smoke wires in light switch and terminal box.
Thanks |
07-27-2014, 03:05 PM | #2 |
Re: Amp meter
It is possible that a burned out shunt or a loose wire on one of the ammeter terminals could be the cause of the generator running wild as it would then not be connected to the battery. However, I believe that it is unlikely that is the cause.
I would more suspect a poor ground on the battery. The connection where the battery ground cable bolts to the frame is the most overlooked electrical connection on a Model A. It is out of sight, out of mind, and difficult to get to. Remove the floor board and the battery and unbolt the ground strap from the frame. With a small disk sander clean the raised boss on the frame where the cable attaches until it is shiny metal. Wire wheel the cable and the nut and bolt. You want to do this at least every ten years or whenever you replace the battery. Tom Endy |
07-27-2014, 03:17 PM | #3 |
Re: Amp meter
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
