Old 04-08-2020, 03:23 PM   #1
marcel kristoff
marcel kristoff's Avatar
Default Original body decal
I have a related/not related question. I am wanting to replicate an original ‘decal’ found on the body of my 1928 AA truck. My question is, what is the type of decal or sticker called? It was obviously not a plotter cut piece of vinyl, and it isn’t hand lettered. What did they use back then? Was it similar to the decals on plastic model kits? What is the proper name for that type of sticker?
Marcel Kristoff,
Fort St. John, B.C.
Canada
marcel kristoff is offline   Reply With Quote
Old 04-08-2020, 05:27 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Original body decal
Any existing photo's?
www.whidbeymodelaclub.com
Old 04-08-2020, 05:52 PM   #3
Ed Wendell
Ed Wendell's Avatar
Marcel,
Most likely in those days it would have been a water transfer decal. A multi layer process to make them, most likely screen printed, 1st screen a layer of glue, next layer(s) would be colors then a clear layer on top. Soak it in water and it slides off of the backing paper.
Ed
Ed Wendell is offline   Reply With Quote
Old 04-08-2020, 07:49 PM   #4
J Franklin
J Franklin's Avatar
I think you can get water transfer material to make decals on your printer.
Old 04-08-2020, 09:52 PM   #5
marcel kristoff
Is there an easier way to post photos on here?
I will look into the water transfer suggestion.
Marcel Kristoff,
Fort St. John, B.C.
Canada
Old 04-09-2020, 01:06 AM   #6
Tudortomnz
Tudortomnz's Avatar
In the day, image was built up by printing separate colours [ also gold & silver] & black using separate letterpress printing plates. Printed on 'transfer 'paper with top sealed layer. As Ed stated above.
If you photo your existing 'decal' transfer, you can get modern type decal paper to copy it onto. I presume it is a Canadian body builders decal as most '28 '29 Canadian cabs were custom made?. If you look online, there are some youtube vids showing how to make custom decals for guitar headstocks which should be of help.
Tudortomnz is offline   Reply With Quote
Old 04-15-2020, 10:52 AM   #7
JoeCB
JoeCB's Avatar
Yes you can buy printer paper to do your own "water slide" decals. With all the high tech graphic arts capability out there these days its fairly easy to get original images reproduced.... often easier to get vinyl appliques than true water slide decals though. Just as a historical aside, "decal" is an abbreviation for decalcomania. I see the original word in parts literature from back in the 20's and 30 's
Joe B
JoeCB is offline   Reply With Quote
