Old 05-25-2020, 04:44 PM   #1
JOHNCL
Default no spark in my Model B fixed
I tried all the usual suspects for a no spark problem at the end of the winter. Nothing worked. Then I removed the points and used a metal file to make them shiny; an emery board didn't do the job but the file did. SHAZAAM! A hot spark happened.
JOHNCL is offline   Reply With Quote
Old 05-25-2020, 05:57 PM   #2
Gary WA
Gary WA's Avatar
Default Re: no spark in my Model B fixed
Thanks for the update on your fix!!
www.whidbeymodelaclub.com
Old 05-26-2020, 06:49 PM   #3
CWPASADENA
CWPASADENA's Avatar
I have run into problems with replacement Model B points. They seem to have almost no tungsten and will burn in a very short time. If your problem keeps happening, replace the points
My experience
Chris W
CWPASADENA is offline   Reply With Quote
