Old 04-14-2020, 11:40 AM   #21
Tod
Default Re: My first iron OHV casting!
Picked up some more cylinder head bullion today. 12 Winfield iron and the first OHV iron sample. They look very nice. Can't wait to machine the OHV. Winfield machining has already run parts.
Tod
Tod is offline   Reply With Quote
Old 04-19-2020, 01:14 PM   #22
Tod
The rocker cover pattern for these new OHV heads. Finish pass CNC cut yesterday. Next is the inside.
Tod
Old 05-01-2020, 06:26 AM   #23
JOHNCL
Tod, Gordon Eliot White's Leo Goossen Archives has copies of blue prints for both of the push rod heads, each penned by Goossen when at Miller and then at Schofield. I have those in my files. The Schofield print would permit you to verify exact water passageways/jackets, etc.
JOHNCL is offline   Reply With Quote
Old 05-02-2020, 07:22 AM   #24
Raypickup
Wow the OHV casting looks great very interested to follow your progress
Raypickup is offline   Reply With Quote
Old 07-31-2020, 08:19 PM   #25
SUHRsc
SUHRsc's Avatar
Any updates on the OHV, Tod?
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 07-31-2020, 08:35 PM   #26
Synchro909
Synchro909's Avatar
The more I see, the more I like what Tod is doing. I wish I could afford one but it would cost me twice as much as it would you guys.
I am mildly surprised that the combustion chamber is not hemispherical. I'm sure Tod will have considered it but I'd like to hear why he decided against doing it.
Old 07-31-2020, 08:41 PM   #27
Lawrie
Lawrie's Avatar
any updates on the blocks?
Lawrie
Old 08-01-2020, 08:24 AM   #28
updraught
updraught's Avatar
Currency conversion is getting better. It'll be cheap when it gets to 2011 rates again.
$US is dropping:
updraught is offline   Reply With Quote
Old 08-01-2020, 10:43 AM   #29
Jim Brierley
The original Miller/Cragar's required A LOT of spark advance to develope good power, Dodgde's suggestion is very good. Also, the originals used 6 cyl. Buick rocker arms, 1.25:1 ratio. I would recommend 1.5's for several reasons, like, most performance cams are ground for 1.5:1 rockers, and valve lift is very important.
