Old 02-28-2012, 11:04 AM   #1
David Lien
Default 4" Crank In Pre War merc. Block
This project has set for ten years +. I have the valves in and adjusted. Next comes the Crank. My question to this board is ??? Do I need to know anything special to install the 4" Crank in this block. Have the bearings and will do this today.I have done this before but after many birthday partys I tend to miss a few things... Thanks I most likely need all the help I can get.
David
David Lien is offline   Reply With Quote
Old 02-28-2012, 11:16 AM   #2
Bruce Lancaster
Default Re: 4" Crank In Pre War merc. Block
Drop in...use pulleys (on some late cranks you'll have to remove the little slinger sleeve as that is part of early pulleys) from Merc, also flywheel, and early main bearings. You can use either the floater earlt rods or the laocked late rods, and your block will need the appropriate seal holders for a rope seal crank...many prewars will have the ones for slinger type crank.
Bruce Lancaster is offline   Reply With Quote
Old 02-28-2012, 12:00 PM   #3
David Lien
Thank you Bruce: I have all the "Stuff" will use the 8BA type rods and do have the oil seal holder. I hope to have this engine in My 46 Ford Coupe this spring. Thanks again David
Old 02-28-2012, 12:24 PM   #4
TomO
Don't forget to change the timing gear. The Merc crank gear is different that the 59A gear.
TomO
TomO is offline   Reply With Quote
Old 02-28-2012, 12:47 PM   #5
tiquer
Sorry not trying to confuse anyone but should it have the early or late gears?? I plan to do this same thing in the near future
tiquer is offline   Reply With Quote
Old 02-28-2012, 01:06 PM   #6
flatjack9
flatjack9's Avatar
Depends which distributor you use.
Old 02-28-2012, 05:48 PM   #7
Ol' Ron
Ol' Ron's Avatar
Doesn't make any difference which set of gears you use with either distributor drive. Keep the back lash to a minimum. I've never seen a speck for this but .005 to .010" should work just fine. I just checked an 8BA abd it was .022" with no gasket. Now the only way to fix that is to install aspacer behind the distributor drive gear.
Be nice if someone could come up with some ford specs for this. Alwaysd use early gears in my engines.
Old 02-28-2012, 08:02 PM   #8
rotorwrench
rotorwrench's Avatar
I would use the early gears in an early engine just to keep me sane so I don't get confused later on. I ain't getting any younger for sure.
Old 02-28-2012, 11:03 PM   #9
David Lien
Thanks Ol' Ron The crank is in. All looks good, I will check the back lash on the dist. gears, and I will use the early crab dist. David
Old 02-29-2012, 01:30 AM   #10
columbiA
I would use the early gears when using the crab dist .The 8BA gears have the helix cut the opposite way.
columbiA is offline   Reply With Quote
Thread Tools
Display Modes
