Old 09-18-2011, 07:18 PM   #1
Detroit Flathead
Default Starter for 8BA Flathead with Merc-o-matic
I recently learned that a 1951 Mercomatic / Fordomatic starter has different mounting with a tab for a bolt sticking out from main body, a different drive assembly, and different toothcount. I'm mounting this to an 8BA Flathead. I need some help determining if either of the starters pictured below are for an 8BA with a Merc-o-matic. I've been told the one on the left is, with the tabs on it, but it doesn't seem to mount correctly. Can anyone else throw in their two cents? The starter on the left with tabs has 9 teeth. The other starter, with the corkscrew shaft, has 10 teeth. Does anyone have a picture of their Flathead with automatic transmission and starter installed? If these aren't for an automatic, do you have one for sale?
If this looks familiar, it's because I also posted in on Jalopy Journal a week or two back. Perhaps I can get more info here. Thanks.
Detroit Flathead is offline   Reply With Quote
Old 09-18-2011, 08:49 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: Starter for 8BA Flathead with Merc-o-matic
I think the left one is the one but not sure of the bolt poatten. I have one in my storage barn that came off a flathead with and auto. I'll check it tomorrow. Walt
Old 09-18-2011, 10:02 PM   #3
Bruce Compton, Canada
I have a rebuilt one that came off a '51 Ford with a Fordomatic. I can bring it to Hershey if that helps. Bruce
Bruce Compton, Canada is offline   Reply With Quote
Old 09-19-2011, 07:04 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
This is what the one looks like for my '51. The two thru bolts fasten to the bell housing along with one bolt and nut in the tab. It has a 9 tooth drive gear. Neither one of the ones you have look correct.
Old 09-19-2011, 07:11 AM   #5
Detroit Flathead
Thanks you for your replies, gentlemen.
51 Merc-CT: That starter looks like it would fit. My Merc-o-matic is from a '51 Merc. Thank you for the picture.
Bruce Compton: I'm interested in yours.
Old 09-19-2011, 07:55 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Your starter on the left also looks much like the starter I fixed on a 58 lincoln.
Old 09-20-2011, 09:30 AM   #7
Merc Cruzer
Merc Cruzer's Avatar
Detroit:
I have a 53' Merc and the I too went through the same issue. The difference was one was for the automatic and the other was for the standard trans. The one on the left is for the auto trans.
Merc Cruzer is offline   Reply With Quote
Old 09-22-2011, 10:23 PM   #8
Detroit Flathead
Merc Cruzer,
Thanks for the picture and info.
Old 07-31-2020, 09:42 AM   #9
WABOOM
WABOOM's Avatar
Here's a pic of my Merc-o-matic starter from my '51
WABOOM is offline   Reply With Quote
