Old 12-02-2021, 10:14 AM   #21
airjam
Default Re: ideas on a cheap wash tub?
Harbor Freight $8.99
https://www.harborfreight.com/7-gall...g_q=mixing+tub
airjam is offline   Reply With Quote
Old 12-02-2021, 11:31 AM   #22
katy
katy's Avatar
Originally Posted by airjam View Post
A little small, the listing says: The mixing tub is an ample 22-1/2 in. x 16-1/4 in. x 6”.
Old 12-02-2021, 11:44 AM   #23
Big hammer
Originally Posted by ronn View Post
yes Old blue, didnt look big enough to my eye. was thinking that would be fine for 19s.
looked up diameter of barrel and it is exactly 22.5 same size as whl, so prob wont work. was thinking I could use the metal barrel for other things like scrap fire.
didnt know I could get a tub that wide at walmart. will check that out as well.
cement mixing tub at vac bags both sound good. where does one buy molasses?
is better then or the same as the vinegar? I use the vinegar in my rads and gas tanks as well and has worked great for me, wo paying for evaporust at 90. for 5 gallons.
An over stuff barrel is a barrel that a normal 55 drum fits into should work if you can find one. Cleaning several at one time would be better than one or two at a time, oh and the cost of the vinegar!
get a bigger hammer tap done
Old 12-02-2021, 04:07 PM   #24
Dennis Pereira
Dennis Pereira's Avatar
This is what I use for wheels highway crash barrel, but it would take a lot of vinegar. Thats a hood panel hanging.
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 12-03-2021, 03:03 AM   #25
ronn
a 55 gallon barrel is 22.5 wide- so is a 21" rim...............
dont think it will work-
a lot of incorrect answers......lol- like I said, Brents idea will work. I have the supplies here- just being lazy!
Old 12-03-2021, 09:36 AM   #26
Al Mack
. . . a lot of incorrect answers . . . lol . . . like I said, Brent's idea will work . . .
Yes and no.
Wheels are 6" tall laying on a flat surface . . . 2" x 8" lumber (7 1/4" wide) would be needed as a minimum unless you want to wait twice as long per wheel. I would also suggest nailing/screwing a plywood or particle board panel to the bottom of the framework so that you can move it around once the juice is dumped in it. White vinegar was running $4.00 per gallon last week.
Al Mack is offline   Reply With Quote
Old 12-03-2021, 09:59 AM   #27
Robert/Texas
Robert/Texas's Avatar
For one at a time use, I suggest using a burn barrel lid. I have one and it fits over the barrel so it has a larger diameter than the barrel. I bought it at a farm and garden store for around $30.00.
Robert/Texas is offline   Reply With Quote
Old 12-03-2021, 10:19 AM   #28
McMimmcs
McMimmcs's Avatar
Try to find a used livestock watering tank.
Old 12-03-2021, 01:07 PM   #29
ronn
I bought vinegar at 1.88 a gallon in the last month on sale. I buy 10 at a time.
Al, plywood can also be used in the framing, thus getting a tight fit and not using far to much vinegar. still find that as the best "fit".
saw the kids pools outside at a diff walmart this morning and have to tell you, I'ld need about 30 gallons of vinegar to fill it.
the barrel lid sounds like a winner...........
Old 12-03-2021, 05:11 PM   #30
Merc Cruzer
Merc Cruzer's Avatar
How about a wheel barrel
Merc Cruzer is offline   Reply With Quote
Old 12-04-2021, 12:17 PM   #31
Dennis Pereira
How about a leaf bag?
Dennis in Kelsey ca
Old 12-04-2021, 12:27 PM   #32
Mister Moose
Mister Moose's Avatar
28 inches in diameter.
$35.
https://www.tractorsupply.com/tsc/pr...b?cm_vc=-10005
Mister Moose is offline   Reply With Quote
Old 12-04-2021, 02:06 PM   #33
ronn
that is the one Mister moose that old blue and I spoke about at beg of thread. my thinking was it might be too tight at the bottom because of the taper.
if its 28 at the top- then just maybe it would work.
in the meantime, I was walking around my property out back and found an old steel cement tray. the wheel fits in nicely about 24" wide. round might be preferred, but this should due just fine. forgot I had it, because it hasnt been used in maybe 15-20 yrs.
will pull the vinegar out of the roadster gas tank next week and reuse it in the tray for a wheel. will give it 30 days and see how it goes.
again thanks to everyone. great ideas!
Old 12-04-2021, 04:00 PM   #34
SAJ
SAJ's Avatar
Ronn, acetic acid (vinegar) reacts with iron and zinc as in steel or galvanized buckets. It also fizzes up in contact with concrete or concrete containers and gives off carbon dioxide. In these cases you are losing much of the effect by neutralizing the acetic acid by dissolving the container. In the case of a concrete container very rapidly. Plastic of any kind seems like a more viable solution to me.
Vinegar reacts more quickly with rust than with bare iron, so an iron container may work ok, though it will be dissolved somewhat with each use
SAJ in NZ
SAJ is offline   Reply With Quote
Old 12-04-2021, 05:40 PM   #35
ronn
thank you for the insite SAJ
I never studied chemistry and havent a clue.
Old 12-04-2021, 07:56 PM   #36
SAJ
SAJ's Avatar
Ronn, almost all acetates are soluble in water, so the iron/vinegar reaction compound will dissolve in the vinegar and any residuals rinse off with water. You then have a "nascent" iron surface which will rust very quickly. So a great thing to do is paint the de-rusted surface with phosphoric acid, or a rust preventive based on Phosphoric acid like Ospho. This forms a skin of iron phosphate, insoluble in water unlike iron acetate, and a great surface for painting, powder coating etc. Even better is to wait for the"nascent" surface to flash-rust, then phosphate it with Ospho etc, since iron oxide rust reacts quicker to form a thicker iron phosphate film than raw iron does .
"Nascent" literally means "at birth"
Apologies if you already know all this!
SAJ in NZ
Old 12-04-2021, 08:10 PM   #37
SAJ
SAJ's Avatar
Ronn,
You are forming iron acetate with the vinegar, which is dilute acetic acid. Metal acetates are soluble in water and so will dissolve in the vinegar solution. Any residues left will Wash off with water.
You are then left with a "nascent" (literal meaning "at birth") iron surface, which will flash rust rapidly.
So a great thing to do is paint it after the vinegar treatment with phosphoric acid or a phosphoric acid-based product like Ospho.
This forms iron phosphate, an insoluble skin which is great for painting or powder coating.
You probably know the Model A body steel was treated in this way when made.
The flash- rust reacts quicker to form a good phosphate layer than the raw "nascent" iron itself.
Chemistry and chemical names simplified in the above!
SAJ jn NZ
Old 12-04-2021, 08:13 PM   #38
SAJ
SAJ's Avatar
Oh no. I thought I lost the original, so wrote it all again.
At least I didn't shout!
SAJ in NZ
Old 12-05-2021, 04:04 PM   #39
ronn
well SAJ, you got me to read it 2x and I needed to. makes good sense. thanks!
Old 12-05-2021, 04:37 PM   #40
40-A Twins
40-A Twins's Avatar
This is the tub I made to soak some rims for another old car project in vinegar. There was a leftover 10" cardboard concrete tube form that I cut and spliced with glue to make a hoop about 24" diameter, then made a box with some old boards to make sure the hoop would not collapse when full of liquid. 2 Brake drums stacked in the center reduced the volume needed to fill it. 4 gallons of vinegar at $1.58 each diluted to 50% was enough to fill it. A sheet of cardboard underneath helps protect the plastic sheet from puncture, and I am careful when putting a rim in since this is 3.5 mil sheet.
Last time I made one of these cheap bathtubs it was sized to hold sheetmetal hood pieces, and when those were done, I transferred the liquid in a plastic garbage can and de-rusted everything that would fit. The tub only has to last until all the parts are done, then gets dismantled.
I would like to try using molasses, but there are nasty little stinky ants around here that would probably find it attractive and have a population explosion.
Kevin
40-A Twins is offline   Reply With Quote
