04-27-2019, 07:11 AM | #1 |
B/W t86 tranny input bearing retainer seal
My 1959 ford T86 B/W tranny has no seal for the input bearing retainer spline shaft that carries the clutch throw out bearing. My old tranny book show some illistrations of having such a seal and others don't show that seal. I certianly do not want 80/90 gear oil to escape onto the clutch friction plate so I am asking where do i get a part number or even did that shaft need a seal??
04-27-2019, 08:57 AM | #2 |
Re: B/W t86 tranny input bearing retainer seal
Some B&W transmissions were set up with seals and some weren't in that era. My early 51 Mercury cars with the 49/E51 overdrive transmissions used no seal on the retainer snout.If it has one then a replacement is available but if it doesn't, I wouldn't worry about it.
04-27-2019, 08:58 AM | #3 |
https://cgfordparts.com/ufolder/ford...r=B7AZ-7A283-A |
