Old 04-24-2016, 07:29 PM   #1
unclevinny
Default t 56 3 spd tranny with od
shifting out of 1st gear is impossible above 1000 rpm, works smothly @lower rpm HELP!!
unclevinny is offline   Reply With Quote
Old 04-24-2016, 08:01 PM   #2
scrapiron
Default Re: t 56 3 spd tranny with od
Clutch adjustment problems ?....Disc spline sticking?
scrapiron is offline   Reply With Quote
Old 04-24-2016, 08:09 PM   #3
unclevinny
might be but it was working at higher rpm just like they used to
Old 04-24-2016, 08:11 PM   #4
unclevinny
i can fool with the adjustment some and try that tommorrow
thanks
Old 04-25-2016, 08:32 AM   #5
Ole Don
Ole Don's Avatar
Remove the lower cover on the bell housing. Have a buddy or the bride step down on the clutch, and watch what happens up inside. If you find rust, a light spray should help, but keep it away from the friction surface. I adjusted my clutch so a .030 feeler would fit between the flywheel and the disc when the pedal was down.
Ole Don is offline   Reply With Quote
Old 04-25-2016, 08:39 AM   #6
unclevinny
ok I will go for that i have the inspection cover off already so will put it on blocks safely and adjust to that thanks i hope it is what the Dr ordered!
