09-25-2021, 01:31 AM | #1 |
Question on flathead oil canister filter housing
Addressing various engine items in preparation for when I get my flathead back from the builder.
Cleaning up the housing and pulled the brass fitting near the top on the side of the housing...... standard male pipe thread with inverted flare for the oil line at the other end...... TINY 1/16" clearance hole in this fitting. Is that correct? |
09-25-2021, 03:52 AM | #2 |
Re: Question on flathead oil canister filter housing
That is correct. It limits the amount of oil that is allowed to flow to the BYPASS filter. If too much were allowed to flow it would reduce the amount of oil available to flow to the bearings etc.
The restrictor must be installed between the engine outlet and the filter inlet. If installed on the outlet of the filter it puts more pressure into the filter and makes it more prone to leak. Mart. |
09-25-2021, 04:21 AM | #3 |
Correct 1/16" Brass Fitting for Oil Canister Housing. |
09-25-2021, 08:55 AM | #4 |
Cool. Thanks for that guys.
When I replaced the bottom fitting on the housing because of a weep at the flared portion, that one was merely a "standard" item. I was surprised at the amount of restriction in this upper fitting...... |
09-25-2021, 09:44 AM | #5 |
In a measured flow test at idle speed, 5 qts. of oil flowed in 11 min. thru the restriction..
09-25-2021, 10:12 AM | #6 |
09-25-2021, 05:16 PM | #7 |
If the center tube in the filter canister that goes thru the middle of the filter and is connected to the return line has this 1/16th hole, is that not the essential flow restrictor? Leaving the only reason to having this fitting(as pictured above) with the restrictor hole would be to reduce cannister pressure to prevent leaks?
With a restrictor hole on the inlet to reduce the flow, wouldn't that actually increase pressure in the cannister as well?
Sometimes, ingenuity gets in the way of sense and sanity. |
09-25-2021, 06:51 PM | #8 | |
Probably a design change to eliminate over pressure in the canister.
09-27-2021, 12:51 PM | #9 |
Did a little researching and some reading, defies logic but makes sense. The small hole will reduce flow and pressure in the canister when installed on inlet side, interesting.
09-26-2021, 11:08 AM | #10 |
I would always want this restrictor to be on the inlet side of the original type filter. These "drip-feed" units don't have that good of seals in the top plate or top-nut/bolt . . . too much pressure/volume, they tend to leak - all over your engine and garage floor! LOL
