08-02-2012, 08:33 AM | #1 |
1st Time Flathead build-Need advice
Just got good news that the flathead block I bought last year checked out OK after a hot tank and mag.
It's for my old truck and I don't want to build a nasty street machine or anything. Stock stroke, 3/4 cam, 4 barrel intake and Edelbrock heads and probably a hotter ignition. My plan is to get the surfaces cleaned up, bored out to the next higher number (.010, 020, 030), and new cam bearings installed. I was then going to bring the block back home and install one of H&H's stock 3 3/4 crank kits myself. Does this sound reasonable? The machine shop warned me that sometimes the aftermarket pistons/rings can be off by a few thousanths. Is it worth just having them do the install, or is this something I can do myself? |
08-02-2012, 08:49 AM | #2 |
Re: 1st Time Flathead build-Need advice
First of all, you need the pistons so the machinist knows how big to bore the cylinders. Why would you want to buy a 3 3/4" stroke crank? They are as plentiful and cheap as the day is long. Buy a 4", 4 1/8" or 4 1/4" assembly. Have you ever built an engine before? There is a difference between putting an engine together and building a proper engine.
08-02-2012, 09:13 AM | #3 |
If you are going to buy a crank kit go for the 4" at least ---and make sure it is all balanced ---had a 46 1-1/2 ton truck, going to 4" was the difference between --I think I can, I think I can to ---no mountain too steep
08-02-2012, 09:15 AM | #4 |
You can buy brand new assemblies from:
http://www.scatcrankshafts.com/index.php#2 Find a local to do the job if you don't have the experience or tools. Make sure the shop has done FLATHEADS before. Go here for some great info: http://vanpeltsales.com/ |
08-02-2012, 09:26 AM | #5 |
I don't want a 4" stroke! I want to keep it 3 3/4".
08-02-2012, 09:45 AM | #6 |
08-02-2012, 10:10 AM | #7 |
Understood. I just wanted to know if having a block punched out say, .030 over would mate up to .030 pistons and rings out of a catalog. I thought it was a safe assumption that they would. Some say yes, some say no. I thought I'd ask the flathead experts if tolerances were that important in a basically stock motor. This is my first build of any kind of motor.
08-02-2012, 10:17 AM | #8 |
Use the original stock 3 3/4 in. crank and save some money. Also, use adjustable lifters. Keep in mind that the OFFENHAUSER 4 bbl. intake offsets the fan carrier bracket 7/8 in towards the driver side which causes it to NOT line up with the crank pulley. That is a problem.
08-02-2012, 10:29 AM | #9 |
The answer I got on your question of matching machine shop bores to oversize pistons is this. If the pistons are of a new build the tolerances are so much better today in manufacturing it is ok to bore the cly before you get the pistons. If you are using old stock you should match the bore to the piston. Either way the person assembling the motor needs to check each fit and ring gap.
08-02-2012, 10:42 AM | #10 | |
08-02-2012, 10:42 AM | #11 | |
08-02-2012, 12:07 PM | #12 | |
08-02-2012, 12:25 PM | #13 | |
I have an Offy on mine and didn't notice it until I tried to re-install a fan shroud. ( fan was hitting the shroud on the drivers side ) The situation was rectified when I fabricated a new fan mount with fan axle moved 7/8" to pass.side.
08-02-2012, 12:29 PM | #14 |
Well, I'm going to have the machine shop fit the pistons. I just called to let him know and he laughed and said "good idea!". Guess he knew I was out to prove myself wrong
08-02-2012, 02:52 PM | #15 |
Just a couple of last questions, why would anyone bore the block before obtaining the pistons? Would anyone purchase pistons without knowing what bore would be needed to clean up the cylinders?
08-02-2012, 06:20 PM | #16 |
08-02-2012, 08:20 PM | #17 |
All things considered, I think you'll be much happier if you let your machinist fit the bores to whatever pistons you purchace. It eliminates any question that the appropriate piston clearance can be made exactly the number you're looking for rather than 'pretty close'. OMO
08-03-2012, 01:35 AM | #18 |
I couldn't believe how noticeable the 4 inch crank is over the 3 3/4 in a stock 8BA. Terrific low-down grunt. A real stump puller - best thing you can do to a flathead in my opinion.
08-03-2012, 02:21 AM | #19 |
I purchased Frank Oddo's book..........and had a good read BEFORE i started my first flattie.............glad i did.......
08-03-2012, 06:27 AM | #20 |
One point and one question.
Point:The single most important modification in many folks' opinion is a set of headers. Save some time and call RED's..... Question: What kind of 3/4 cam are you considering?
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
