Old 11-19-2018, 10:55 AM   #1
jwilliams81
jwilliams81's Avatar
Default 31' Town Sedan Rear Door strap replacement?
My rear door strap(check) snapped in half over the weekend.
This is the part:
https://www.snydersantiqueauto.com/flat-strap
How does this piece get replaced?
Do I have to take the door panel off and the side panel?
Any pictures or tips would be really helpful.
Thanks
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 11-19-2018, 12:13 PM   #2
duke36
Default Re: 31' Town Sedan Rear Door strap replacement?
Yes; you have to remove the door panel enough to access the 2 screws. Sometimes a stubby or rt. angle screwdriver will fit without completely removing the panel. The other end fits behind the quarter uph. panel and the metal panel which accesses the window/mechanism.
duke36 is offline   Reply With Quote
Old 11-19-2018, 12:14 PM   #3
burner31
burner31's Avatar
You need to get under the door panel and the quarter panel.
I'll see what pics on my computer I can find (if any) on that area
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-20-2018, 08:33 AM   #4
jwilliams81
Thanks, any pictures as to how it all goes together would be helpful.
Cincinnati, Ohio
