02-11-2021, 03:19 PM | #1 |
1951 f3
Good afternoon. I am looking for some guidance on my dad's truck. Is it easier to assemble the whole front clip as an assembly or put it together piece by piece? Any benefit or drawback either way? Thanks in advance
Sent from my SM-G960U using Tapatalk |
02-11-2021, 04:58 PM | #2 |
Re: 1951 f3
Consider if you assemble everything together off the truck ,radiator support, inner fenders, outer fenders, grille and any associated parts, they should be loosely assembled to allow for adjustment, then you probably need three or four people to lift it into place.
I always preferred to start with the radiator support and assemble on the truck.
02-11-2021, 08:48 PM | #3 |
Re: 1951 f3
On my ‘52 F1, I put the inner fenders on first and then put on the fenders and other pieces. It was pretty straightforward that way.
02-11-2021, 09:46 PM | #4 |
Re: 1951 f3
I'm 67 and my son is 26. For years we have assembled the whole front clip off the truck. Each of us on a side and we just set it on. As said, bolts barely snug. Then we adjust and tighten bolts. Now we have you all confused since we all have different Ideas. My thing is since I'm an older guy and sore and tired after work, we always lift away the front clip for engine swaps or whatever work to be done. It's the horrible rust bolts to cut etc on the first removal, but with stainless/galvanized/cad plated bolts and nylock nuts etc. After that the front clip in total just lifts away when access is needed, And Access is huge at 67, believe me.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-11-2021, 09:53 PM | #5 |
Re: 1951 f3
Thank you guys for the responses. Lots of good ideas. I appreciate the advice. If the weather ever breaks here it is first on the list!
02-11-2021, 10:27 PM | #6 |
Re: 1951 f3
You padded the rear running board bracket. Was that before or after barking a shin on it?
I dig coal, which provides motivation for EVs. |
02-12-2021, 09:35 AM | #7 |
Re: 1951 f3
Lol, after many close calls with the fender brackets in the garage, the foam was necessary. Yes, also went the 5 lug route and a 9 inch for highway cruising. Wheel choices are also better. Thanks for the reply.
