Old 05-07-2020, 09:34 PM   #1
tommyleea
Default 53 Ranchwagon Radiator
Had my radiator recored. Are the brackets on correctly? The fan is very close to the radiator. I think if the brackets were switched it would give me more room..Help..Thanks
tommyleea is offline   Reply With Quote
Old 05-08-2020, 01:03 AM   #2
HOTRODPRIMER
HOTRODPRIMER's Avatar
Default Re: 53 Ranchwagon Radiator
The radiator in my '54 Ranch Wagon appears to be mounted the same way. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 05-08-2020, 08:14 AM   #3
tommyleea
Great..Thanks..I know the brackets were marked when removed, but it has been a long time. I guess I need to adjust my flatty some to give me a little more room. Thanks again.
Old 05-08-2020, 08:27 AM   #4
51504bat
51504bat's Avatar
I have the stock radiator out of my '54 Ranch Wagon on the floor in my shop. I can take some measurements and photos of that would help. Just have to go and do it. Let me know.
51504bat is online now   Reply With Quote
Old 05-08-2020, 10:51 AM   #5
tommyleea
That would be great if it's not too much of a hassle. Appreciate it. Thanks
I think mine is correct, but the fan is just too close.
Old 05-08-2020, 12:00 PM   #6
Bob C
How close is to close, got a picture.
Old 05-08-2020, 12:17 PM   #7
Bruce_MO
On my '53 Ranchwagon (also recored), the brackets look to be about 7/8" in front of the core. The back side of the core is about 1" from the fan. I took several cell photos and I'm happy to share, but I've never figured out how to post pictures. If you want photos, PM me and I'll send somehow.
Bruce_MO is offline   Reply With Quote
Old 05-08-2020, 01:20 PM   #8
51504bat
51504bat's Avatar
Photos attached. The side bracket is not the same distance from the core at the top and bottom. It goes from 3 1/4 at the top of the bracket to 2 1/4 at the bottom.
Old 05-08-2020, 01:41 PM   #9
JayChicago
JayChicago's Avatar
Close is not a bad thing. 1/2" to 1" is ideal, I think, for pulling air through the radiator. Any further away, parasite air gets sucked in from around the perimeter of the fan rather than pulled through the radiator fins.
JayChicago is online now   Reply With Quote
Old 05-08-2020, 05:11 PM   #10
tommyleea
Thanks for the pictures. Mine are on correctly. I will just have to loosen the mounts, and maneuver the engine a little bit. I know the holes in the frame had some adjustment to them. I am almost there. Thanks again.
Old 05-09-2020, 06:53 AM   #11
rotorwrench
rotorwrench's Avatar
The radiator in post 8 appears to be for a 6-cylinder and they may be different from a V8 radiator.
Old 05-09-2020, 06:58 AM   #12
tubman
tubman's Avatar
Also, unless you know for sure, assuming a '54 ("Y"-block) radiator set up is the same as a '53 (flathead) puts you on shaky ground.
tubman is online now   Reply With Quote
Old 05-09-2020, 07:59 AM   #13
51504bat
51504bat's Avatar
Nope. Had a 239 Y-Block that I removed. It could be that '54 radiators are different than '53 but this is definitely from a '54 Ranch Wagon with a
239 Y-Block.
