Old 04-16-2018, 06:02 PM   #1
sofield
Default Rear end rebuild/using new bearings with old brg
Lets assume the carrier races good. Is it wise to use new bearings with old races on a rebuild? Or are we heading down the road looking for problems of rear end noise and early bearing failure. What are other members thoughts
on the subject?
Sofield
sofield is offline   Reply With Quote
Old 04-16-2018, 06:04 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Rear end rebuild/using new bearings with old brg
If the races are good why aren't the bearings?
Old 04-16-2018, 06:17 PM   #3
Jim M
Jim M's Avatar
I just went through at total rebuild of rear end, drive shaft, tranny, and clutch. EVERYONE I talked to said to do it right always replace the races with the bearings which is what I did. I love to do these projects, but I HATE to do them the second time which is what I did a few times when I first got started. Just my humble opinion.
Jim M is offline   Reply With Quote
Old 04-16-2018, 07:02 PM   #4
Bill Pursel
Bill Pursel's Avatar
Replace bearings and races
Bill Pursel is offline   Reply With Quote
Old 04-16-2018, 08:19 PM   #5
Tom Endy
Tom Endy's Avatar
The race is the other half of the bearing. Replace them both. It is always prudent to replace all bearings, races, seals, and gaskets.
Over the years I have people bring a rebuild job to me and say "If the bearing look okay go ahead and reuse them". I tell them I won't take on the job unless all bearings, races, seals, and gaskets are replaced.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 04-16-2018, 09:11 PM   #6
J Franklin
J Franklin's Avatar
With poorly made or counterfeit parts I always cringe if I have to replace a good working part if it is within tolerance.
Old 04-16-2018, 10:03 PM   #7
Pinesdune
Pinesdune's Avatar
Always replace the race with a bearing, it's a cardinal rule in the world of pulling wrenches. If you feel the bearings and races are serviceable , that's your call, but try not to mix up bearings to races and mess with established wear patterns. Listen to Mr. Endy, he wrote the manual
Pinesdune is offline   Reply With Quote
Old 04-16-2018, 10:23 PM   #8
racingrufus
racingrufus's Avatar
As Mr Endy said new brgs new races.
racingrufus is offline   Reply With Quote
Old 04-17-2018, 06:33 AM   #9
Growley bear
Installing a new bearing cone in a used bearing cup is like polishing a car with 100 grit sand paper.
Growley bear is offline   Reply With Quote
Old 04-17-2018, 07:25 AM   #10
daren007
I have seen many bearing cups that needed replacing while the cone was still in serviceable condition and vice versa.
daren007 is offline   Reply With Quote
Old 04-17-2018, 07:54 AM   #11
SeaSlugs
SeaSlugs's Avatar
Heres a question along these lines:
When you buy new rotor hub assemblies for any car there are bearing races already pressed in. When you buy wheel bearings it comes with races as well. Do you use the new bearings with the races that are already in the hub or do you knock them out and press the ones supplied with the bearing in?
I've done it both ways and never had issues (except when i had one side a tad too tight and bearing started growling)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
