Old 01-03-2021, 11:36 AM   #1
39flyer
Default 3.55 rear end ratio
What vehicle was the 3.55 ratio used in. I purchased, what I thought was, a 3.54 set from a Barn member but it had a 32 tooth gear and 9 tooth pinion. It’s a new set and apparently came from Speedway. But they don’t list a 3.55.
39flyer is offline   Reply With Quote
Old 01-03-2021, 11:51 AM   #2
mcgarrett
Default Re: 3.55 rear end ratio
Might want to check with Van Pelt Sales on that question. http://www.vanpeltsales.com
Old 01-03-2021, 12:19 PM   #3
tubman
tubman's Avatar
"32/9=3.55555555" ????????
Old 01-03-2021, 01:20 PM   #4
deuce lover
deuce lover's Avatar
I had a set of those.They are made by Motive (Italy) I got them from Baxter Ford in KS back in 2009 and had them installed in a 36 Banjo rear.Worked fine.
Old 01-03-2021, 01:24 PM   #5
rotorwrench
rotorwrench's Avatar
The set I purchased (Italian made) was too large a diameter on the wide part of the pinion quil to fit through the opening in the center section. The wide tips of the gear have to be ground down with a tool post grinder to get them to fit but they work fine after they fit.
Old 01-03-2021, 02:13 PM   #6
G.M.
I have a 3:55 rear in of my 39 convertibles. Powered by one
of the brand new Canadian truck engines available over 40
years ago. Very seldom had to down shift for a hill. I ran it
from S W Florida to Phila. 15 or 20 times non stop at 75 to
80 MPH. Only had cooling problems a few times at 100 out
side temp and traffic slowed down. I have about 150,000
on it now and sounds and runs good and may use 1/2 quart
between changes. With Skips turbine type impellers and the
radiator rodded out it runs at 165 degrees. Also with the clean
radiator and the power of the coolant be forced through the
radiator it looks to me like scrubs the radiator, see pictures.
You also need a 4lb pressure cab and a recovery bottle. A
larger fan is very helpful. With a cool engine the oil does not
get as black. They shipped the engine to me with truck heads
they used only for shipping, being new I left them on. G.M.
www.fordcollector.com
Old 01-03-2021, 02:50 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Ford did use a 3.54 ratio during many of the 'banjo' years. The tooth count was 11/39. No 3.55s specifically! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-03-2021, 03:08 PM   #8
Brian
Brian's Avatar
As duece lover states, they are Italian made Motive brand. I'm running a set. The only issue, easily remedied, is the pinion is ground to the same 'press fit' dia where the bearings are located. The portion of shaft that the outer bearing locates on needs to be polished down [I think from memory about .001"]to enable the outboard bearing to just slide...this enables one to correctly set pinion preload.
Old 01-03-2021, 10:47 PM   #9
my4dv8
Originally ,39 mercury I believe . We found a 39 mercury pinion and crown wheel local , just had to cut off the full length pinion and respline it to std. ford 6 spline length.
my4dv8 is offline   Reply With Quote
