12-02-2011, 11:50 PM | #1 |
Thread size 39 temperature bulb in cylinder head
Does anyone know the size of the hole in the drivers side head of a 39 ford. And pushing my luck does anyone also know the size of the hole in a 40 cylinder head. Thanks.
12-03-2011, 08:05 AM | #2 |
Re: Thread size 39 temperature bulb in cylinder head
The size of the hole is the same for both, I think 3/8 IP size. The 39 had a ledge at the bottom of the hole for the capillary tube temp sender and the 40 was drilled straight thru because the electric temperature sender was larger.
12-03-2011, 08:39 AM | #3 |
The heads set up for a temperature bulb have if I remember correctly a 1/2-20 thread, not a pipe thread. And I believe the sender ones are 3/8" pipe. G.M.
www.fordcollector.com |
12-03-2011, 09:48 AM | #4 |
If you are looking for the thread size for the 39 with the bourdon tube temperature gauge I believe it is the same for the earlier car 5/8-18
The 40 Ford electric sender is 3/8-18 NPT |
12-03-2011, 01:50 PM | #5 |
There is an adapter for pipe thread to temp gauge, I think it was used on 60hp cars(at least the 39 my father had used one)---try looking in the "green book"
12-03-2011, 03:42 PM | #6 |
12-03-2011, 06:49 PM | #7 |
These adaptors are available from Napa, they have a pretty good assortment. An older Napa store might be better. I know a lot of people jambed pipe thread fittings in the straight threaded holes. G,M,
12-05-2011, 07:54 PM | #8 |
Yes, the adaptor made for installing aftermarket tube-type gauges into pipe holes. Functionalyl right, no idea if appearance is right on. Cheap, often sold in a bag with an assortment of adaptors for various applications. Any company selling about any brand of hotrod gauges will have an equivalent.
