03-03-2011, 06:55 PM | #21 |
Re: 59AB heads on a 8BA block
Thanks everyone - I'm no longer ignorant - at least in that regard!
03-03-2011, 10:54 PM | #22 |
why? now you can't run modern thermostats.
03-04-2011, 02:20 PM | #23 |
Yes I feel better and read most of the threads related to engines. I'm pleased to find that there is plenty pf expert advice here so I don't have to try and answer every thread, just the ones that ruffle my feathers. Your in good hands.
03-04-2011, 02:46 PM | #24 |
03-05-2011, 07:20 AM | #25 | |
19forty,where is spacer placed and what does it look like.. |
03-06-2011, 02:15 AM | #26 | |
Ol' Ron Good to see your smiling face again. Hope you are doing ok.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
03-06-2011, 09:11 AM | #27 |
Im runnin 81 heads and modern thermostats, no problem.
Had to clear a bit for the valves. |
07-25-2013, 01:07 PM | #28 |
The spacer is an aluminum spacer ring that sets on top of the cam cover . The distributor goes thru it and raises the distributor to the same height it was when using the stock 8BA heads. You can see it on the left edge of the photo with the black line going across it. It is 1/4 in. thick. You will have to make one. My distributor is a Mallory.
07-25-2013, 06:35 PM | #29 |
