Old 09-12-2020, 12:03 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Tire Ooze Cleaner
I have Universal tires on my 190A and they are oozing a brown substance through the sidewalls. I have tried many, but I have not found a tire cleaner that takes the ooze off thoroughly even after brushing. I am all ears & eyes for your recommendations.
Bob Bidonde
Old 09-12-2020, 12:29 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Tire Ooze Cleaner
Have you tried Westleys Bleche-White? That stuff used to take everything off whitewalls, would probably clean off blackwalls just as well.
Old 09-12-2020, 12:34 PM   #3
McMimmcs
McMimmcs's Avatar
I had a set of Universals that I replaced with GoodYears. The reason was I could never get the w/w clean. Lesson learned buy cheap don’t expect quality. I’ll Never buy them again .
Old 09-12-2020, 01:44 PM   #4
JOHN CT
JOHN CT's Avatar
https://images.app.goo.gl/m37s5r3GCgsQYdy47
I’ve had pretty good luck with this on discolored tires
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 09-12-2020, 02:21 PM   #5
Bob from Northport
Bob from Northport's Avatar
Simple green cleaner and Westley's
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 09-12-2020, 03:11 PM   #6
dmaxweb
dmaxweb's Avatar
I don't have a "before" picture but mine were like you described, maybe worse. This is what I used and I am very happy how they turned out.
Super Clean
https://superclean.com/products/supe...ner-degreaser/
Followed by:
Rubber Care
https://washwax.com/products/rubber-care-32oz
dmaxweb is offline   Reply With Quote
Old 09-12-2020, 03:17 PM   #7
bavArian
bavArian's Avatar
You can clean whitewalls with NevrDull. It works quite well, but I'd wash them off with soapwater afterwards just to be sure.
bavArian is offline   Reply With Quote
Old 09-13-2020, 10:26 AM   #8
katy
katy's Avatar
It sounds like they were never cured properly when being manufactured.
Old 09-14-2020, 09:02 AM   #9
Bob Bidonde
Dmaxweb, thanks for the tip, I will try Super Clean.
Bob Bidonde
Old 09-14-2020, 09:08 AM   #10
Roger V
Roger V's Avatar
I had a brownish-goldish hew on my Firestones on the A in my avatar after either sitting for awhile or sun exposure. I use STP's Son of a Gun tire cleaner which works very well.
Roger V is offline   Reply With Quote
Old 09-14-2020, 09:16 AM   #11
dmaxweb
dmaxweb's Avatar
Super Clean tires on Youtube:
https://youtu.be/U027HlrtwzA
