Old 05-16-2021, 08:26 AM   #1
Terry,OH
Terry,OH's Avatar
Default 1940 style generator rear end plate.
I found an old 41 Ford generator with a cast iron rear end plate. What I have seen, in the past, is the white metal die cast end plate. The cast iron end plate does have the 01A- Ford part number. Does anyone have any additional info about this end plate? Such as when it may have been originally used?
Old 05-16-2021, 08:55 AM   #2
Kube
Kube's Avatar
Default Re: 1940 style generator rear end plate.
That's a new one on me Terry. Interesting indeed.
Old 05-16-2021, 10:03 PM   #3
deuce_roadster
deuce_roadster's Avatar
Maybe because of wartime, aluminum was saved for airplanes and the end plate was a replacement. I have a couple of 21A distributors that are wartime cast iron.
deuce_roadster is online now   Reply With Quote
Old 05-17-2021, 06:13 AM   #4
Terry,OH
Terry,OH's Avatar
deuce roadster: Also my thoughts, especially since the generator has late 41 date code (V-11) with the armature date coded the same (for 42 production). I did not think the rear light weight plate was aluminum (pot metal or white metal) but it could be.
From my present day knowledge the USA was partially gearing up for the war prior to Dec. 7th
Old 05-20-2021, 04:11 AM   #5
fortyonerag
fortyonerag's Avatar
Interesting. I wonder if this was also done with starters?
fortyonerag is offline   Reply With Quote
Old 05-20-2021, 05:11 AM   #6
HD
I have re built 100,s of those generators, I have seen and I have many of those end plates, most of the ones I have done were on large Ford trucks F600 and larger'
HD is offline   Reply With Quote
Old 05-20-2021, 07:25 AM   #7
Terry,OH
Terry,OH's Avatar
The end plate is on a passenger car generator 21A-10000 dated 11/1941
