10-25-2013, 08:55 PM | #1 |
Schrader valve
Picked up a Schrader valve that screws in spark plug hole to pump up tire the other day,looks like nos,but check valve is not working,only pump 10-15 lbs,anyone took one apart?Thanks
10-25-2013, 09:46 PM | #2 |
Re: Schrader valve
Randell, Dog here, DON'T pump up yo' tires with thet thingy, it'll put GAS VAPOR in yo' tires & the HEADLINES will read, "BIG- BAAAANG" Buster T.
10-26-2013, 12:26 AM | #3 |
Re: Schrader valve
Yea seems like a bad idea to be driving around on a bag of pressurized gasoline...
Im sure theres some kinda rubber or leather diaprham that moves and supposed to block a port off but has dryrotted.
1929 Model AA - Need long splash aprons! |
10-26-2013, 03:07 AM | #4 |
Re: Schrader valve
Yea I would think the vapors from the engine would not be a good thing for the tubes. We seem to have tube troubles already today without adding anything but air.
10-26-2013, 05:32 PM | #5 |
Re: Schrader valve
It's made to pull air in from outside,but I am sure some comes thru carb.
10-27-2013, 04:21 AM | #6 |
Re: Schrader valve
10-27-2013, 06:52 PM | #7 |
Re: Schrader valve
The rubber has drawed up,have to find something to make one.
