Old 07-31-2021, 07:22 PM   #1
aussie merc
aussie merc's Avatar
Default current draw king seely gauges
HI wondering if anyone knows how much current king Sealy gauges require as have converted to 12 v now need to fit reducer and need to Know current draw Thanks in advance
aussie merc is offline   Reply With Quote
Old 07-31-2021, 07:39 PM   #2
JSeery
JSeery's Avatar
Default Re: current draw king seely gauges
There are reducers for this that do not require any knowledge of the current draw. A simple solution is to use any later model Ford voltage drop unit, salvage yards are full of them and not that expensive new. Something like a 65 Mustang will work, Ford used the same type of 6v gauges up into the 80s I believe, so they all required a voltage dope unit.
HAMB reference: https://www.jalopyjournal.com/forum/...auges.1134282/
Old 07-31-2021, 08:29 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
As stated all that is needed is one Ford instrument cluster voltage reducer such as this from EBAY as well as others ---
https://www.ebay.com/itm/19173104525...QAAOSwwbdWOQzm
Old 08-01-2021, 06:40 PM   #4
Ross F-1
Ross F-1's Avatar
Each gauge and sender draws about 600 mA, at least on my '52 truck. So peak max draw of 3.6 amps.
I had one like 51-Merc linked to, and could see the voltage regulator cycling on the gauges. I switched to this type and they are rock steady:
(edited to correct unit)
https://www.ebay.com/itm/26402911996...UAAOSwNo9b439q
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-01-2021, 07:21 PM   #5
JSeery
JSeery's Avatar
Are you sure you linked to the correct one? That unit is rated at 12v output, not 6v.
Old 08-01-2021, 07:23 PM   #6
Ross F-1
Ross F-1's Avatar
Oops, you're right, it is this one:
Old 08-01-2021, 07:28 PM   #7
JSeery
JSeery's Avatar
That looks better.
Old 08-02-2021, 07:40 AM   #8
19Fordy
19Fordy's Avatar
Ross, will that converter still allow the stock 6V voltage regulator to read accurately?
Old 08-02-2021, 08:02 PM   #9
Ross F-1
Ross F-1's Avatar
Do you mean the ammeter? It has no effect on that, only oil pressure, gas, and temp gauges.
