09-06-2024, 04:20 PM | #1 |
Gas line fitting
Am building a carburetor test stand out of shop scraps, and need to fab a gas line . I went to the hardware store where they have (almost) every fitting known to man, but could not find this one. What is the correct name for this fitting?
09-06-2024, 04:27 PM | #2 |
Re: Gas line fitting
Try a Model A parts vender. Hardware stores do not carry Model A parts
09-06-2024, 04:35 PM | #3 |
compression fitting and ferrule...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
09-06-2024, 05:08 PM | #4 |
I see that they all carry the fittings, and they call them 'gas line fittings'. The huge selection of compression fittings in the hdwr store all had female threads, no male threads, except for connectors. If this is fairly unique to Model As, I am happy to buy from our faithful vendors, but I am hoping to walk in, find the correct little plastic drawer, and walk out with the fitting.
09-06-2024, 05:27 PM | #5 |
Try an auto parts store.. should have it
Joe B |
09-06-2024, 06:16 PM | #6 |
09-06-2024, 07:34 PM | #7 |
When a hardware store has "gas line fittings" they are most likely for natural gas (as in water heaters and stoves), not gasoline. Auto parts store, as suggested, for fuel line fittings. I don't recall but the inlet to a Zenith might be standard tubing compression fittings as 1955cj5 says. Those might be available at your local hardware store.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
09-06-2024, 07:53 PM | #8 |
FUEL LINE BRASS FITTING LARGER 9/16 INCH HEAD 1/2-20unf 1928-31
09-06-2024, 10:11 PM | #9 |
In your second photo the ferrule is located too far inward from the tip of the tube. It should be approximately 1/8" in from the tip.
09-07-2024, 06:55 AM | #10 |
The only place I was able to find this fitting is through the Model A suppliers,
Keith |
09-07-2024, 07:32 AM | #11 |
09-07-2024, 09:09 AM | #12 |
McMaster-Carr is a good source for all kinds of fittings:
https://www.mcmaster.com/products/fi...copper-tubing/
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
09-07-2024, 04:01 PM | #13 |
You need a better hardware store!
09-07-2024, 04:40 PM | #14 | |
https://www.snydersantiqueauto.com/p...9363&cat=41707 |
09-07-2024, 06:02 PM | #15 |
That oversize ferrule is very useful.
09-07-2024, 07:37 PM | #16 |
Just a little hint that may be useful... if you have a problem with a leaking compression fitting. First sweat solder the ferrule to the tube before tightening the fitting. With the normal application the "nut" must compress both the ID and OD of the ferrule to form a seal. Pre - soldering the ferrule ensures no leak on the ID side and much less compressive force required.
Joe B |
09-08-2024, 08:43 AM | #17 |
That's a great idea JoeCB!!!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-08-2024, 09:16 AM | #18 |
This slide shows where the ferrule needs to be relative to the end of the tube.
Bob Bidonde |
09-08-2024, 09:41 AM | #19 |
A good source for fittings, fuel and brake lines, is your local junk yard, (er... I meant to say, "Automotive Recycling Center". Many yards still have an "old" section and would have these parts available. Even if you come up empty, spending a couple of hours cruising through an old junk yard, is a joyous thing.
09-08-2024, 11:08 AM | #20 |
Thread Tools | |
Display Modes | |
