Old 06-21-2019, 04:25 PM   #1
raggity
Default Model A light switch on 56 f100 steering box
How can I use the model A light switch on my 56 f100 steering box?
raggity is offline   Reply With Quote
Old 06-21-2019, 04:34 PM   #2
foxfire42
foxfire42's Avatar
Default Re: Model A light switch on 56 f100 steering box
Did you modify the unit yourself for use or purchase one already done? There should be a hole the full length of the shaft to accommodate the light rod. I got the one from Randy Gross. He makes them for the different rod lengths on the 28/29's and 30/31's and the stock light switch items should connect right up.
foxfire42 is offline   Reply With Quote
Old 06-21-2019, 07:12 PM   #3
Chris Haynes
Chris Haynes's Avatar
Mine from Randy Gross uses all of the Model A lighting parts.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is online now   Reply With Quote
Old 06-22-2019, 09:12 AM   #4
Nosetime
Nosetime's Avatar
I needed a longer horn rod for mine, but yes it had been modified correctly for the A. Just have Randy do a box for you- won't find a better guy.
Nosetime is offline   Reply With Quote
Old 06-22-2019, 03:23 PM   #5
Chris Haynes
1921 Runabout
1930 Tudor
Early 1930 AA
