Old 06-10-2015, 05:51 AM   #1
jon laing
Default Fixing paint chips
After spending many hours looking for paint codes and finding out that suppliers have problems dealing with old paint codes I found a simple solution. Most NAPA stores have a special camera that identifies the proper formula to match your car color. Then they can mix small or large quantities of the type of paint you need. Hope this helps someone. Jon L.
jon laing is offline   Reply With Quote
Old 06-10-2015, 07:57 AM   #2
john worden
john worden's Avatar
Default Re: Fixing paint chips
Yes the camera can be an aid but they search their data base for a color formula that is as close as they can get to your color. Tinting may be required which is not a bad thing at all. It does not produce a new formula that matches your color.
Technology to produce a match would certainly be welcome.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 06-10-2015, 09:02 AM   #3
jon laing
Seems like finding the color that most closely matches ones car is all that is needed for chip repair unless one is truly a perfectionist. Jon L.
Old 06-10-2015, 09:14 AM   #4
BILL WZOREK
BILL WZOREK's Avatar
Don't know about all NAPA dealers but our local one can mix the paint & put it in spray cans also.
BILL WZOREK is offline   Reply With Quote
Old 06-10-2015, 10:00 AM   #5
dean333
dean333's Avatar
Send a message via Yahoo to dean333
NAPA the parts store mixes paint and puts in spray cans??? Wow that's news to me, have to check that out.
Tim Carlig
dean333 is offline   Reply With Quote
Old 06-10-2015, 11:18 AM   #6
BILL WZOREK
The local Napa does 01060 zip code
