02-05-2015, 02:47 PM | #1 |
Paint after brake clean
I cleaned some brake fluid residue from the outside of a booster with brake clean. Can I prime and paint now without any further prep?
Tim Carlig |
02-05-2015, 02:53 PM | #2 |
Re: Paint after brake clean
I'm not a professional painter! But I would use something like carb cleaner or lacquer thinner to wipe it down and dry it well before attempting to paint it. Might want to use a brake fluid resistant paint as well.
02-05-2015, 02:58 PM | #3 |
I use brake clean, then paint with good success. sometimes I use a heat gun to slightly warm the part to evaporate what is left and make the primer flow better
02-05-2015, 03:13 PM | #4 |
Whenever I clean something with brake cleaner I always follow it up with carb cleaner. I always felt it left a better finish on the part to prep it. But 4dy can't disagree with success.
02-05-2015, 03:25 PM | #5 |
Thanks Guys.
Tim Carlig |
02-05-2015, 03:42 PM | #6 |
02-05-2015, 05:10 PM | #7 |
Eastwood Company sells paint for the boosters, One of their products will restore the original "plated" appearance.
