Old 06-16-2013, 02:03 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 36 Original Upholstery Cleaning
Has anyone successfully cleaned 77 year old upholstery without shredding or ruining it? I want to keep the car original as much as possible and yet clean the mohair a little. I was thinking a good vacuuming or maybe lightly steam clean it?? Any experienced feedback or suggestions?
1936 Fordoor Sedan
dean333 is offline   Reply With Quote
Old 06-16-2013, 08:52 PM   #2
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: 36 Original Upholstery Cleaning
1936 Fordoor Sedan
dean 333 .......................
What ever you do, shampoo, etc., you should vacuum it first.
To keep the material from being sucked into the vacuum cleaner, fasten a piece of panty-hose, over the nozzel. You might have to clean the panty-hose often, but it's worth it. It will let the dirt through, but will keep your material stable.
Good luck,
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 06-16-2013, 08:58 PM   #3
md8810
look into dryice cleaning/blasting. This process is used more in Europe for restoring art and fabrics.
Mark Detwiler
md8810 is offline   Reply With Quote
