08-06-2023, 03:46 PM | #1 |
Wedged shaped body bolt spacer
Is there a source for these or do I have to make them?
Respecting and Resurrecting Ford Model A's. |
08-06-2023, 03:57 PM | #2 |
Re: Wedged shaped body bolt spacer
Could that "wedge" shape be part of the cross member.
08-06-2023, 04:37 PM | #3 |
Might want to check with Third Gen. on these. Roy N. carried them years ago with part number R-933. $5.00 for a pair.
08-06-2023, 05:02 PM | #4 |
08-06-2023, 05:07 PM | #5 |
Thank you for your help guys
08-07-2023, 12:03 AM | #6 |
08-07-2023, 10:24 AM | #7 |
Just curious:
What purpose does that wedge spacer serve? |
08-07-2023, 10:41 AM | #8 |
Most 32 Fords from the factory used the wedge spacer on the back body mount bolt between the frame and body. At the thick part they were a tick over 3/8th, (just guessing) Over the years most of them were lost when the body was removed from the frame and washers substituted. I have made some spacers in the past but a factory mfg one would be great. I never knew they existed until i was at Dave Crouse's garage and he showed me a 5 window that had never been disassembled, it had the spacer.
08-07-2023, 08:28 PM | #9 |
JayChicago,
the spacer made the connection of the body bolt perpendicular, so direct pressure was applied to hold the body to the frame. |
08-08-2023, 11:41 AM | #10 |
Nelsb01
Thanks. Now that you explain it, it seems so obvious. |
08-08-2023, 03:50 PM | #11 |
One inch of 4" channel iron will give you 2 of them. Drill the holes then cut them off.
Bruce
Works good Lasts long time |
08-09-2023, 06:38 PM | #12 |
Really? Hah. I have never seen one at my ace. I will look again.
08-09-2023, 06:54 PM | #13 |
Just order them from Third Gen
