10-10-2023, 01:45 PM | #1 |
1940 ford with 9" rear , wheel cylinder question in regards to brake line size.
This may have been asked many multiple times. i have searched but cannot come up with answer , and i know i am overthinking it.
1940 ford (actually merc, but for question purposes we will say ford) with stock drums up front 9" in rear with 11" drums. manual master I have not ran any new brake lines yet, i can go either way, but was leaning on sticking with 1/4 lines. MY QUESTION IS : If sticking with 1/4 lines is it as simple as screwing adapter into my later wheel cylinders to fit the 1/4 lines ? (or proper fitting 1/4 tube 3/8 thread ?) I have ran a similar setup on a 34 tudor i built 10 years ago or so, but i cant for the life of me remember what i did LOL ,joking aside it seems like at the time i found the proper fitting at the parts re-sellers and just reflared the 1/4 line with a correct size thread fitting for the later wheel cylinders. but haven't been able to find the thread fittings . |
10-10-2023, 02:53 PM | #2 |
Re: 1940 ford with 9" rear , wheel cylinder question in regards to brake line size.
I've done quite a few customer chassis with this brake combination and right or wrong I've always used 3/16th lines. Since these have all been hot rods I also used #3 stainless braided lines on all 4 corners. As much as I hate to admit it I've had good luck with Speedway fittings. I can't remember ever using 1/4 inch line on any of the 100's of customer chassis I've plumbed over the years.
10-10-2023, 04:00 PM | #3 |
Me too: I have done dozens of fords with 3/16" standard lines with 9" ford rear ends with 10" and 11" drums with 11" and 9" discs on the front. and 3/16"
line have 3/8" 24 threads per inch fittings......... Your 1/4" lines are for fuel.......... |
10-10-2023, 04:35 PM | #4 |
done this on a couple of cars (12"lockheeds on front, 11" bendix on back ) with 1/4 " lines ( just because that"s how henry did it ) & parts store adapters & it always worked fine. the only bender i had was a 1/4 imperial so thats what i was comfortable with. 3/16" or 1/4" , doesn't really matter.
10-10-2023, 05:00 PM | #5 |
