08-09-2012, 12:40 PM | #1 |
Battery Requirements
I was wondering if a battery with 730 Cranking Amps and 590 CCA is sufficient or should the cranking amps be more to supply power to the Model A starter.
Thanks for your time. Joe Grobleski |
08-09-2012, 02:04 PM | #2 |
Re: Battery Requirements
6 volt or 12 volt?
Stock or modified (high compression head, for example)? If anywhere near stock, this is more than enough battery.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
08-09-2012, 03:38 PM | #3 |
Sorry, its a 6 volt system although it will have a touring cam and high compression head.
Thanks, Joe Grobleski |
08-09-2012, 03:45 PM | #4 |
I bought an Optima battery, 1,000 cranking amps & 850 cold cranking amps!!
If I run out of gas,+&$*%@%, I can probably "CRANK"myself down to Bad Bud's for gas! Bill W.
08-09-2012, 06:21 PM | #5 |
My Optima would race Bill's to Bad Buds for a Bud. |
