08-09-2012, 12:27 PM | #1 |
Brake shoe twist
As part of my rebuild I'm reviving my front mechanical brakes with a floating brake energizer kit from Mike's and a shiny new set of springs. After installing the new lower springs, the spring on the front shoe on one wheel gets really tight and twists the shoe outward so that its liner is no longer parallel to the hub. The rotation is bad enough that I have to force the hub to get it back on and it certainly doesn't turn freely, despite the brake wedge being all the way up.
I've already checked to make sure that the rollers on the bottom of the shoe are aligning correctly with the new plate and there is clearance, as it should, from the old track. My first thought is that there is too much play in the connecting shaft between the shoe and the adjustment wedge. But asking that pin to apply enough torque to prevent twisting seems like a lot to ask of that remote part. I tried more than one spring and oriented them a couple different ways with the same result. Any ideas? What additional info should I provide to help you give good advice? |
08-09-2012, 01:27 PM | #2 |
Re: Brake shoe twist
do you have the top of the shoes pinned ?? do that before you put the springs on the bottom ............. steve
V4f |
08-09-2012, 08:40 PM | #3 |
The link should fit with a little up-down in the housing to allow for centering, but should be pretty tight in the in-out direction. ---the link has a somewhat oval form |
