08-06-2012, 06:15 PM | #1 |
horn
My horn sounds sick Is it much of a job to rebuild it I am not a mechanic
08-06-2012, 06:24 PM | #2 |
Re: horn
Rebuilding is tough. Maybe you just need to clean the commutator, lube the felts, and ensure a good ground. That's all pretty simple stuff.
08-06-2012, 06:31 PM | #3 |
Re: horn
assuming you have an original horn usually all it needs is cleaning of the armature where the brushes ride, oiling of the felts at both ends of armature (not too much!), adjustment of the tension screw and good clean & tight electrical connections. sometimes the trouble is in the horn button or light switch rather than the horn itself. got a dead horn right now on one of our As, I suspect it's in the button, haven't taken time yet to bypass the button and see if it works......
our next Model A is out there in the unknown...... |
08-06-2012, 09:56 PM | #4 |
Re: horn
I fixed my friends slow sick horn by just holding a small piece of fine sandpaper against the commutator while holding the horn button down. After several seconds of this it took off like I added a supercharger!
I finally got around to doing the same thing to my slow horn a few weeks ago. Also add a few drops of oil to the felts at each end of the armature. The horn cover screw will pull some on the horn motor frame, so make your final adjustment with the cover on. One click can make a big difference. |
08-06-2012, 11:11 PM | #5 |
Re: horn
My horn would barely spin. I picked up a spray can of electric motor cleaner at Home Depot. Flushed the horn guts, still on the truck. I'm glad I had several rags protecting the hood and fender. I was amazed how much crap came out of my horn. A little adjustment was all that was needed. My horn works great now. A very easy fix.
08-07-2012, 12:56 AM | #6 |
Re: horn
08-08-2012, 08:07 PM | #7 |
Re: horn
Tom and Wello ;
Thanks for the info on cleaning the horn . I too had a sick horn . Followed your cleaning tip and now the horn sounds as it should . This forum has given me a lot of good tips on many things. |
08-08-2012, 09:29 PM | #8 |
Re: horn
Clean the comutator with acetone or lacquer thinner to get the grease off. Then lightly oil the felts.
08-09-2012, 01:22 AM | #9 |
Re: horn
Somewhere I read that you should oil the horn every 3 months.
Wouldn't it be trick to have lube stickers made that included all the unusual lube & oiling stuff that just applies to The Model A? Bill W.
