11-20-2010, 04:44 AM | #1 |
Gas Tank Galvanizing
I just had my gas tank cleaned at a facility similar to Ready Strip.
The tank is now clean and ready to be sealed. I was wondering if anyone has used a hot dip galvanizing on their tank instead of a pour and slosh sealer. |
11-20-2010, 09:28 AM | #2 |
Re: Gas Tank Galvanizing
sounds interesting, but I'd want mine to be cut open before galvanizing to be certain that it's completely cleaned.
what problems will galvanizing cause with painting the visible surfaces? what would we seal the welds with after putting it back together? also sounds expensive. still plenty of good tanks showing up at swap meets. |
11-20-2010, 10:42 AM | #3 |
Before you use sealer on the tank, I suggest that you read the many threads that have been made here on Fordbarn. There is one such thread currently open near this thread. I personally will not use any sealer again after having it come out of my '30 Coupe tank. I now only use a fine screen on the fuel inlet / shut off valve in the bottom of the tank. Gar Williams
11-20-2010, 11:11 AM | #4 |
I agree with Gar. I've never used a sealer and never would, no matter what they promise about it. I've never had a problem with rust in a tank, but the shutoff valve screen and sediment bulb should take care of any rust or other debris.
11-20-2010, 12:07 PM | #5 |
I read that current thread about sealers after posting this question about galvanizing. I am going to call a couple of plants that do galvanizing and find out if it can be done and how to treat the exterior of the tank so that it will accept paint.
11-20-2010, 12:12 PM | #6 |
Pluck |
11-20-2010, 12:35 PM | #7 |
If it was a good idea, surely more people would be doing it. I'd call a gas tank manufacturer-like Tanks, Inc-and ask their advice. I would bet you'd end up with flakes of the galvanizing floating around in your gas.
11-20-2010, 12:38 PM | #8 |
A quick Google search didn't run up much, but there was a posting on another site about contacting Steve at The Filling Station (Chevy site) for information about who dies it.
11-20-2010, 02:48 PM | #9 |
The 1930 cabriolet that I just sold that was restored in the late 50s was shiney inside and looked to me like it was galvanized. I assumed that this was the original ford finish because I saw no sign of The tank ever being cut apart.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
11-20-2010, 04:26 PM | #10 |
Elrod,
Go to my website and read all about the makeing of the Model A/AA Ford gas tank...I am sure that will enlighten you on the subject. Pluck |
11-20-2010, 06:58 PM | #11 |
Pluck,
Thanks for the website, very informative. So the gas tanks were originally galvanized. |
11-20-2010, 07:43 PM | #12 |
WELL.....If "Terne plating" is another term for "galvanized plating" then yes...otherwise NO.
Somewhere on the World Wide Web it tells the difference and I do not know where that is...anybody? Pluck |
11-20-2010, 08:20 PM | #13 |
I believe Terne plating is tin, while galvanizing is Zinc.
11-20-2010, 08:30 PM | #14 |
terne was 20% tin, 80% lead
11-21-2010, 04:13 AM | #15 |
Coated in lead (solder) is terne
11-21-2010, 09:31 AM | #16 |
I would guess the biggest problem with galzanising (and I'm assuming you mean hot dip galvanising) is that of getting the molten zinc to flow out of the tank when removing it from the vat. I wouldn't volunteer to be the one who has to rock it around to slop the zinc out before it started to cool and set.
I have had reasonable results with tank sealers - I did a motorcycle tank 15 years ago that was very dry and rusty before starting the treatment and it is still fine now, despite just looking like a thin plastic film from the outset. Then a couple of years ago I used a POR15 kit on a '55 F250 tank and that was a real PITA to do - nearly blocked up the 1/4" outlet pipe due to its installation method, but otherwise seemed to work OK. |
11-21-2010, 11:00 AM | #17 |
Wikipedia lists "terne" as traditionally 210% tin and 80% lead. Now it is 50% tin and 50% zinc. It also said it needs to be painted,which sort of eliminates it's value as a tank coating-might as well just use a sealer.
11-21-2010, 01:13 PM | #18 |
With any of the zinc or terne coating processes you would need 100% clean bare metal. That's not easy to get in an 80 year old tank. I hope the fellow in Australia, that's been mentioned before, starts making new ones.
Kerby |
08-02-2022, 01:37 AM | #19 |
I too have considered either doing a coating or galvanizing inside my 1941 Lincoln Zephyr tank. I was able to get an original tank from Merv Adkins in California. I had it sand blasted on the outside and discovered some small pin holes so I soldered them. I will paint the outside of the tank once I'm through cleaning inside and deciding how to proceed. As to hot dipped galvanizing, the problem without taking it apart like a clam shell is it might leak afterwards. Hard to weld back as the metal is very thin. (18AWG?) Anyway there are also baffles inside the tank as most are to keep the noise of the gas sloshing around while driving. You'd never get a good galvanizing job without taking it apart. Now as to flaking of the zinc galvanizing, yes that tank metal is thin, and it will flex some and that can break some of the material off which you could hopefully catch in a fuel filter. Same with the plastic sealant, it's brittle and will flake off too! I will leave mine alone, just acid washed and clean. And I won't use any Ethanol gas as that's alcohol and that attracts water. I get from Shell a non-ethanol gas and that works. The ole V12 loves it too! It would like it better if there also was some lead in it. Not going there and starting a fight with the EPA! Good Luck!!
08-02-2022, 09:05 AM | #20 |
Hello, I think with the advent of ethanol fuel, fuel tanks that were previously sealed in the 1980,s and before weren’t resistant to alcohol content as ethanol fuel wasn’t widely used then ,causing problems today.The newer sealers are supposed to be, I try to use non ethanol in my older cars , ethanol also has a tendency to draw moisture when sitting for a time , boat owners won’t use it.
