09-19-2015, 03:34 PM | #1 |
model b engine and 32 trans in a model a frame
OK, I have put the front axle and rear end in the model a frame. Now it is time to install the model b engine and 32 tranny in the frame. Any suggestions?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
09-19-2015, 04:03 PM | #2 |
Re: model b engine and 32 trans in a model a frame
You will need to buy or fabricate mounts for the pedals and front wishbone. Check to see if your u joint cover fits, they changed the bolt pattern at some point. Your Model A rear motor mounts will not work, the bolt holes on the flywheel covers are in a different location between A and B (they just look that they are in the same location until you look carefully). They may have a float-a-motor mount for this application. When you said you put the front and rear end in I assume they are Model A. What year is your Model A?
Charlie Stephens |
09-19-2015, 04:35 PM | #3 |
The frame and body is 28. I am also installing a Mitchell over drive driveshaft. I heard that snyders makes a bracket for the 32 tranny.
09-19-2015, 05:32 PM | #4 |
Check Clings out for pedal mount , They make some nice stuff, I know they have B4 tranny to A block kit. 5 days till blast off.
09-19-2015, 06:03 PM | #5 |
I am in the process of installing a 34 pickup engine and transmission in my 28 open pickup I am using the front and rear float-a-moter mounts. I am not using the rear transmission mount. As I recall I am using the model a front cover. I can send you some pictures if you would like. Send me your email address.
John [email protected] |
09-20-2015, 06:16 AM | #6 |
09-21-2015, 08:07 PM | #7 |
Any one know where I can purchase rear motor mounts for a model b engine to a model a frame.
09-21-2015, 08:58 PM | #8 |
It has been so long since I bought my motor mounts that i don't remember thevender.
possible the guy in California that had the blue engine stand for sale. S & J or something like. that. He has since closed up shop. |
09-21-2015, 09:12 PM | #9 |
09-22-2015, 07:54 AM | #10 |
Thanks, I will give them a call as soon as they open.
09-22-2015, 03:04 PM | #11 |
Decided to use the model b front motor mount and drill two 1/2 inch holes in model a cross member. As far as the rear mount, the 32 tranny has a bracket near the middle cross member of model a frame so I will make a bracket to support the rear of tranny. I also just rented the drive shaft puller from Mitchell mfg in California. It cost $35 and I can use it for 2 weeks. Wont be long before the new od drive shaft is installed.
09-22-2015, 03:45 PM | #12 |
For $85 you can use it forever.
09-22-2015, 08:22 PM | #13 |
where do I buy it?
09-23-2015, 10:52 AM | #14 |
I bought mine several years ago direct from Mitchell.
09-24-2015, 06:09 AM | #15 |
I called them and made the purchase. Once I get the puller I can install the Mitchell and then put all drivetrain together . Then I can fabricate the rear tranny mounts to the center cross member. Going to use the model b front engine rubber mount set between tranny and bracket.
09-24-2015, 11:22 AM | #16 |
'32 Dump,
Just woke up, BOY was your first pic CONFUSING, 'til I dumped my monitor on its' LEFT side. WOW, you gotta' LOTS OF STUFF! Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 09-24-2015 at 11:39 AM. |
09-24-2015, 01:31 PM | #17 |
Sorry about that. When I uploaded it went sideways. Yeah, the garage is full w tools and antiques.
09-24-2015, 02:42 PM | #18 |
I just thought you had your chassis hanging on the wall to save room.
09-24-2015, 03:11 PM | #19 |
Good looking garage, dump. That's what they're supposed to look like.
Your dump truck ain't so bad either! Looking good. |
09-24-2015, 04:52 PM | #20 |
I did hang the chassis from the ceiling to save room. Chain falls are nice that way. I have the subframe ordered but plenty of work to do on the drivetrain. Got the puller today and it worked sweet. Will install Mitchell tomorrow.
