07-10-2015, 09:20 PM | #1 |
Rear Motor Mounts Needed...
Photos needed: 1. Where the rectangular hole (there are two of them in each support) is 1/4 inch away from the outer edge to which the engine is attached...these are very early and were obsolete between January and March 1928; (The very early type of A-5090-B has just 4 holes, not 6, to attach it to the frame, but I doubt very much that this one does not exist HOWEVER the 6 holer does). 2. Where the rectangular hole is 1/2 inch away from the outer edge to which the engine is attached AND the rectangular holes have 1/8" radiuses in each of the four corners of the rectangle. Thanks. Pluck Last edited by Steve Plucker; 07-10-2015 at 09:38 PM. |
