05-17-2014, 06:50 AM | #1 |
OT - Anthony Michell’s Crankless Engines - The Engine Without a Crankshaft
Michell invented this engine in the mid-teens based on a simple yet ingenious method of eliminating many moving engine parts by replacing the crankshaft, connecting rods and the bearings of a conventional engine with a wobble plate. See many more photos and learn the story at The Old Motor. Last edited by t-head; 05-17-2014 at 07:49 AM. |
05-17-2014, 07:02 AM | #2 |
Re: Anthony Michell’s Crankless Engines - An Engine Without a Crankshaft
That setup looks just like the common R6 air conditioning compressors GM used for many years. When I went to the GM training school to learn about them I started thinking it would make a neat engine.
05-17-2014, 07:10 AM | #3 |
Otherwise known as a "swash plate" engine.
The same principle later adopted in many applications - certainly diesel engine injection pumps. Most notably used on VW diesel engines - but used certainly for at least a generation before. Interesting pix though - thanks! Heh. Honeycomb radiator? Joe in NH
Shudda kept the horse. |
05-17-2014, 07:18 AM | #4 |
wow does one still exist that is working?
Rust and roll will never die |
05-17-2014, 02:30 PM | #5 |
Re: OT - Anthony Michell’s Crankless Engines - The Engine Without a Crankshaft
Very cool... thanks for sharing!
James Johnson 1930 Tudor Sedan & 1939 Deluxe Fordor |
05-17-2014, 02:58 PM | #6 |
Terry |
05-17-2014, 08:04 PM | #7 |
That's COOL! Is it in a 'Michell' ?
05-17-2014, 10:16 PM | #8 |
Thanks for posting this. Looks like it's mounted in a mid twenties Buick to me.
05-18-2014, 06:39 AM | #9 |
This is the cylinder head end of one of Michell's mid-1920s, five cylinder engines w/two plugs a cylinder. It was part of a self contained unit including the flywheel, clutch and transmission. More photos and info @ http://theoldmotor.com/?p=119936 |
05-18-2014, 02:49 PM | #10 |
Looks expensive to manufacture. I remember those GM compressors as being pretty smooth when running.
05-18-2014, 03:02 PM | #11 |
My friend, Corny, had a small, single cylinder, "wobble plate" engine, run by compressed air. I don't know what it was used for???----Bill W.
05-18-2014, 07:12 PM | #12 |
Look up the dynacam engine, now owned by Avec and is called the Axial vector Engine.
