12-22-2013, 11:29 PM | #21 | |
Re: Rust Converters?
12-23-2013, 01:10 PM | #22 |
when purchased, our unrestored Coupe had light surface rust all over the frame, axle assemblies and the underside of body.
I put plastic sheeting on the garage floor, crawled under and sprayed it thoroughly with Ospho. (Ospho will stain concrete seriously if you don't cover the floor) 2 days later I sprayed the areas with rattle can Rustoleum satin black. when we sold the car 9 years and 8,000 miles later, the underside had no visible rust and looked great. it was a MISERABLE & UNPLEASANT job, but it worked. our unrestored 37 Plymouth had the same light surface rust, but I coated it with used gear oil, as recommended by Roger Kauffman in the Model A News. still not a pleasant job but much easier than the Ospho treatment and of course the oil costs nothing. I plan to use the same process on the 35 Chebby this year, but thanks be to God I have a Backyard Buddy lift now, so that "crawling under" nonsense is a thing of the past.......
our next Model A is out there in the unknown...... |
