04-07-2013, 12:36 PM | #1 |
Tom Wessinberg Question. POINTS
Tom, I found a nice '34 Ford in a garage last year and I now have it on the road.
The '34 has a wire wound ceramic resister and I've heard that this resistor is so that the distributor points don't "burn" up. Why is this resistor needed on a '34 Ford and not on a Model A?? Thanks Tom. Jim Boehmke |
04-07-2013, 12:48 PM | #2 | |
Re: Tom Wessinberg Question. POINTS
04-07-2013, 12:52 PM | #3 |
Thanks Tom, Yes. all the early V-8's have these as stock equip.
JIm |
04-07-2013, 01:29 PM | #4 |
Jim,
Here is some info I saved on my computer from the past: MISC. IGNITION VOLTAGE RESISTORS: These consist of a winding of a high resistance (nichrome) wire wound around a porcelain type insulator. This reduces the incoming 6 Volts to between 3 to 4-1/2 Volts (early Ford literature states it’s reduced to 4-1/2 Volts). The thinking at the time was this decreased voltage would increase the life of the distributor points by reducing arcing. And with the difficulty in replacing the distributor points in these front mounted distributors, it was a very good idea. But it required a special 4-1/2 Volt coil. Bypassing, or removing, this resistor from the circuit overloads the internally wound primary circuit in the coil and causes premature coil failure. However, it’s quite common to bypass these resistors when racing to increase the spark being delivered to the spark plugs. Because the car is moving (more air circulation around the coil) and combined with less idling, the coils were less prone to overheating and melting their tar insulation. When the ’49 was introduced, Ford discontinued the voltage resistor for their newly designed ignition system and began using coils rated at 6 Volts. I’m sorry I don’t have who submitted this to the FB site around Dec. 12, 2006. |
04-07-2013, 01:44 PM | #5 |
Great info. Benson. Thanks heaps.
JIm |
04-08-2013, 09:45 AM | #6 |
'31 180A |
04-08-2013, 10:39 AM | #7 |
Ford N-model tractors with the distributor mounted on the front of the timing case used 'em too. By-pass that resistor, and the coil will open-up after about 1/2 hour of running.
