Old 11-25-2016, 06:47 AM   #1
bnchief
bnchief's Avatar
Default Light switch question
Does anybody put dielectric grease on the light switch faceplate thought it might make it turn easier and help to protect the contacts from corrosion good idea or bad?
bnchief is offline   Reply With Quote
Old 11-25-2016, 08:25 AM   #2
JBill
Default Re: Light switch question
Couldn't hurt anything, might help.
JBill is offline   Reply With Quote
Old 11-25-2016, 08:35 AM   #3
bnchief
bnchief's Avatar
thanks bill also found some info in the archives
Old 11-25-2016, 08:39 AM   #4
Mitch//pa
I always do
Old 11-25-2016, 10:25 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by Mitch//pa View Post
I always do
Chief said that VASELINE is a MULTI-PURPOSE lubricant & is good for EVERYTHING-LOL
Chiefs' Son
"THE ASSISTANT GURU OF STUFF"
Old 11-25-2016, 11:52 AM   #6
coupe1942
coupe1942's Avatar
Put Vaseline onto the base of a light bulb and you won't like the results afterwards.
CorrosionX would do the same as dielectric grease. They make a light bulb grease sold at AutoZone and such which is probably better than Dielectric grease.
coupe1942 is offline   Reply With Quote
Old 11-25-2016, 11:55 AM   #7
bnchief
bnchief's Avatar
ok thanks for the suggestions
Old 11-25-2016, 12:37 PM   #8
Mitch//pa
Vaseline melts down to easy
Old 11-25-2016, 01:47 PM   #9
BILL WILLIAMSON
It was meant to just be FUNNIE!
SA Dad
Old 11-27-2016, 06:04 AM   #10
bnchief
bnchief's Avatar
Have switch back together a little grease and it work very nicely
Old 11-27-2016, 09:25 AM   #11
BILL WILLIAMSON
Some say, "A little steering box oil leaking into the switch will RUIN it"!!!----Others will say, "NAW, it will just make it work SMOOTHLY"!!!---What the HECK do we believe????---The Guys that told me this were DEAD SERIOUS about it.
Bill W.
Old 11-27-2016, 10:02 AM   #12
bnchief
bnchief's Avatar
grease and oil is not a good thing there having dealt with it on a 37 ford pickup but checked all connections and light switch positions and they work fine.
Old 11-27-2016, 10:49 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I always lube the switch either with dielectric, or Mystik JT-6 High Temp grease. Both work fine for me.
Years ago I used Vaseline to put in the light sockets on my Scout and trailers. I soon found out about it melting at a low temp and running out of the socket and all over the bulb. Lesson learned.
