Old 08-02-2014, 12:06 PM   #1
DougVieyra
DougVieyra's Avatar
Default Inside Sun Visor for ALL closed cars
As a daily driver, I find my 1931 Dlx Coupe has a glaring short-coming when the sun gets low on the horizon, and the stock outside visor is of no value in blocking the sun from my vision.
Henry Ford solved this problem in the late '31 slant window Model A's, and from then on in Ford production, with the installation of a inside sun visor, like today's modern cars.
So my question to all the many Ford Barners who do drive their Model A's as a daily driver - has anyone installed an after market (I'm not interested in the pricey reproduction brackets for the Vicky & Slant window cars), modern type interior sun-visor in his Model A ?
For those who have, I would like to know the 'who', 'what', 'when' & 'why' of your choice. I am anxious to install an inside visor and am looking to learn from the 'pioneers' who have installed this important and useful tool to safe driving.
DougVieyra is offline   Reply With Quote
Old 08-02-2014, 03:58 PM   #2
al's28/33
al's28/33's Avatar
Default Re: Inside Sun Visor for ALL closed cars
No replies Doug, I think most folks have learned to deal with it the way it is. I use my third hand to block the sun while driving my phaeton.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 08-02-2014, 04:29 PM   #3
Fred K-OR
Fred K-OR's Avatar
I have the opposite problem, I can't see traffic lights because I am to tall and have a hard time to see the lights.
But couldn't you just go down to a junk car lot and get a "modern" shade fairly cheap. Then you may have to take off your upholstery above your windshield and put in a wooden block where you want the sun shade in the metal channel up there. The block would give you something to screw the shade to. Just a wild idea for you. It would mess up your upholstery above your window a bit but you would have your shade.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-02-2014, 04:59 PM   #4
modelAtony
modelAtony's Avatar
My 31 tudor I went to aircraft supply store at local airport and purchased the peel and remove window tint for small planes. stick on and remove and replace where needed. The strips are cheap and use over and over. Have fun modelAtony tony white Lafayette, LA
modelAtony is offline   Reply With Quote
Old 08-02-2014, 05:56 PM   #5
ed thibodeau
In my 31 CCPU I got two out of an older german car (cant remember which one) and mounted them in the wood header above the windshield. they just screwed in with a couple of oval head screws, and they work well. No shafts going into the header like the more modern ones.
ed thibodeau is offline   Reply With Quote
Old 08-02-2014, 08:00 PM   #6
George D
George D's Avatar
A baseball hat or any hat with a visor can be a big help if adjusted right.
George D is offline   Reply With Quote
Old 08-02-2014, 10:25 PM   #7
ian Simpson
I just close my eyes.
ian Simpson is offline   Reply With Quote
Old 08-02-2014, 11:00 PM   #8
amishman
My 1930 Townsedan had them in the car when I bought it. The visors look like they belong in the car, they're mounted to the header above the windshield with wood screws.they work well,pivoting in all directions. A ball mounted on both ends of a L shaped rod and the clamps are tighten to the balls to pivot. I'd post pictures, but won't be home from Puyallup for 2 more weeks, I remember that something is stamped on the brackets, ( maybe--Grand Haven, Michigan )
amishman is offline   Reply With Quote
Old 08-03-2014, 06:41 AM   #9
mshmodela
mshmodela's Avatar
Sorry no recommendations, I'm 6'3" and with longer seat arms my level eye is still at the top frame of the windshield. I think you might have to get creative and take one from another old car and create your own mounting bracket...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-03-2014, 07:44 AM   #10
jimalabam
jimalabam's Avatar
ian Simpson: So you are the dude I met coming at me on the wrong side of the road. hee hee !!!
jimalabam is offline   Reply With Quote
