Old 01-14-2020, 01:46 PM   #1
Humperhill
Default Electric speedometer
Is anyone using an electric speedometer that requires a speed sensor as opposed to GPS for calibrating? If so how did you go about this? Looking at an Autometer product.
Thanks
Eric
Humperhill is offline   Reply With Quote
Old 01-14-2020, 10:16 PM   #2
eagle
eagle's Avatar
Default Re: Electric speedometer
They make an electronic speedometer that uses a magnetic pickup on wheel, but they too need to be calibrated. I used one on a tractor. Otherwise run a speedometer APP on your phone and once you figure out how much your car speedometer is off, you're all set.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 01-15-2020, 02:22 AM   #3
CarlG
CarlG's Avatar
I use a Garmin GPS
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-15-2020, 05:09 AM   #4
johnbuckley
johnbuckley's Avatar
I have attached a bicycle speedo ( about the price of a couple of beers) - cheap chearful and it works
johnbuckley is offline   Reply With Quote
Old 01-15-2020, 07:30 AM   #5
History
History's Avatar
I was going to say this ^^^^^^^. Easy to calibrate, atleast the ones I've used.
History is offline   Reply With Quote
Old 01-15-2020, 02:13 PM   #6
papanick
Hay if you know how far it is off I then can calibrate you speedometer to mach your car. papanick.
papanick is offline   Reply With Quote
Old 01-15-2020, 02:20 PM   #7
Curtis in MA
Were do you place the pickup if you use a bicycle speedometer?
Curtis in MA is offline   Reply With Quote
Old 01-15-2020, 04:56 PM   #8
katy
katy's Avatar
On one of the spokes, make a bracket to mount the pickup. Some of the bicycle speedos are susceptible to RFI from the engine.
Old 01-16-2020, 05:56 PM   #9
Humperhill
Thanks, for the input. I will look into the bicycle speedometer idea.
Eric
