07-05-2017, 05:36 AM | #1 |
head studs
Looked at an engine yesterday that is claimed to be overhauled with a high compression head. The studs all had almost exactly 2 threads above the nuts showing and had hex head slots in them. Never seen those hex slots before - is that a correct stud?
John |
07-05-2017, 05:52 AM | #2 |
Re: head studs
As far as I know, the top of the stud should have a round dome finish
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts http://www.fordbarn.com/forum/group.php?groupid=5 |
07-05-2017, 06:00 AM | #3 |
Re: head studs
ARP studs have Allen wrench holes . Great studs,expensive. not correct for judging
John |
07-05-2017, 07:02 AM | #4 |
Re: head studs
Aloha
what great photos of the cars and freinds...beautiful and brings back memories. Don |
07-05-2017, 07:38 PM | #5 | |
Re: head studs
IF you are talking 'stock' Model A/B Ford, no not correct for judging standards. What you saw and describe are most likely ARP made. If you have ever removed A/B engine heads, you will find that the stock studs are not easy to remove and in lots of cases....snap / break at the block. The ARP studs that have allen or slot type heads , you can use an an allun wrench and/or screw driver to hold the stud and/or remove same...handy but not stock. Last edited by hardtimes; 07-06-2017 at 07:02 PM. |
07-06-2017, 04:02 PM | #6 |
Re: head studs
I had to get new studs machined up out of high tensile steel. These proved more accurate than the set I had bought and the head slipped on effortlessly. It is possible someone had new studs machined up for your motor and thought to add slots to simplify installation? Keith |
